Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-16-2003, 02:15 PM   #1
MySea6
CF Senior Member
MySea6's Avatar
Default Lambs Wool polishing pad ???
I am thinking of using a velcro backed Lambs Wool pad on my P/C random orbital for removal of acid rain etching. Along with 3M Perfect It II 39002 or 3. Then follow up with 3M 39009 and probably finish with the 3M Imperial Glaze or Griots fine polish. Both on foam pads.
What do you think? Would it cut too deeply and create more swirls than it's worth? Or should I just stick with the foam pads?
I understand that less is better when dealing with our less then awesome Vette paint but the foam pads along with 3M 39009 Swirl Remover and the Griots polishes don't seem to cut it. Maybe I should just give it several more applications of the 39009?
thanks/ken
MySea6 is offline   Reply With Quote
Old 01-16-2003, 02:44 PM   #2
DetailingDude
CF Senior Member
DetailingDude's Avatar
Location: Chit!! Somebody keyed my Karma and now I'm pissed
Send a message via AIM to DetailingDude Send a message via MSN to DetailingDude
Default Re: Lambs Wool polishing pad ??? (MySea5)
I have never used a Lambs Wool pad on a RO buffer. However, (and I am just visualizing this) what you many encounter is the product loading up in the knap of the wool. With a rotary buffer the Lambs Wool pads seem to offer greater cutting action but on a RO buffer I am not sure if that could be accomplished. With a rotary or RO buffer and a foam pad there is no loading problems. I just don't know that you'll see the level of cutting action it appears you are expecting.
No problem on the product selection.
Yes, patience is not included in the bottles. :D Just take your time, let the product do its job.
[Modified by DetailingDude, 1:44 PM 1/16/2003]
DetailingDude is offline   Reply With Quote
Old 01-16-2003, 03:57 PM   #3
MySea6
CF Senior Member
MySea6's Avatar
Default Re: Lambs Wool polishing pad ??? (DetailingDude)
I was kinda thinking the same with the wool pad. Think I'll test on my dark blue beater first and keep the rake and a bottle of water handy.
That's great. :D Should be the forum motto :thumbs:
Old 01-16-2003, 07:10 PM   #4
DsC5
CF Senior Member
DsC5's Avatar
I've never used one, but from what I understand of wool pads is that they are the most aggressive ones. I'd be very careful and be sure try my other options first - i.e. yellow (less aggressive than wool but more so than white) or white (least aggressive pads).
DsC5 is offline   Reply With Quote
Old 01-16-2003, 10:24 PM   #5
ketch
CF Member
Default Re: Lambs Wool polishing pad ??? (DsC5)
There is a difference between "wool" pads.
A "cutting pad", the old white wool, is a wool yarn pad, the sheep is sheared, the wool is processed and twisted into a "yarn".
This is then "bonded" to a "backing plate" and while it will "cut" imperfections from the paint film, will be very agressive and leave "micro-marring" of the paint film, wether a clearcoat or a non clear.
It is then necessary to use a polishing pad, either a "lambs wool" or "foam" to remove the micro-mars created.
A "lamb's wool", is not a yarn type pad, but is the actual hide of the sheep, it is treated with a "tanic process" and becomes a "polishing pad".
The concern is the new high solid clear's, easily accept micro-marring, (the correct term for swirls, spider webbing, etc, which are not deep into the paint films substrate.
Neither a "yarn" or "lambs" wool pad were developed for use with a dual action buffer, such as a PorterCable or an orbital.
They are for use with a "rotary" type buffer.
While some may attain some level of micro-mar removal, the time required is excessively time consuming for a professional detailer.
They will use today, the educated ones. a "blended wool/acrylic" type pad to "cut" the deeper scratches from the substrate, and then follow up with either a "lambs wool" polishing pad or a "foam" pad.
On darker colored vehicles, we teach to use the "lambs wool" and then using the same polishing material, to re-polish using a "foam" pad.
There is much more to this, technique, speeds, understanding the chemistry of today's high solid clears, etc, but that is the basic's of using pads.
Ketch :cool:
ketch is offline   Reply With Quote
Old 01-17-2003, 06:51 PM   #6
Intermezzo
CF Senior Member
Default Re: Lambs Wool polishing pad ??? (ketch)
Ah, a good demonstration of the kind of knowledge one should possess before going around and trying to publish a detailing guide, let alone a bible.
Good stuff Ketch. :thumbs:
Intermezzo is offline   Reply With Quote
Reload this Page Lambs Wool polishing pad ???
Tags
acrylic, attachment, buffing, car, cut, lambs, lambswool, lambwool, pad, pads, paint, polish, polishing, stick, wool
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A Bit Confused w/ the Porter Cable??? gtoformula400 Car Care Discussion 9 07-12-2005 03:19 PM
Dealing with swirlmarks danmuff Car Care Discussion 37 05-30-2005 01:39 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
