Detail Spray on a ceramic coated car??
Received 1,105 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I applied the Avalon King this spring, do I need to use a different detail spray now?? Used Turtle Wax Ice Detailer in the past.
I just installed a Wind Restrictor and there's a boatload of fingerprints. Cars not dirty enough to wash...
Moderator
Received 3,763 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
Something like Griot's speed shine, or your quick detailer should do fine with a clean microfiber. Possibly consider something like Wolfgang's waterless wash products to keep on hand.. many times my car just not dirty enough for a 3 bucket wash
Jeff T. (06-16-2022)
Received 1,407 Likes
I would more likely use an SiO2 based spray as a sacrificial layer, like Polish Angel or Kamikaze overcoat.
The following 4 users liked this post by vader86:
Moderator
I haven't seen much difference or benefit to any of the new sio2 based quick sprays I have used I lean all the ceramic and sio2 products towards marketing over performance. That is my actual experience with the many I have tried, I look at results.. nobody pays me to try them I just like to sample new stuff here and there.
Gixxerman (06-17-2022)
I recently started using Adams Graphene CS3 Waterless Wash Ceramic Spray Coating Detail Spray and really like the product. I saw in an online forum that users claim they are diluting the product 1:1 with distilled water without affecting its performance. I would appreciate your comment.
Jim
Thank you for contacting us and thank you for your business!
That is not a product that you should dilute as it is a ceramic based product and water and ceramic will not mix together.
Best,
Adam's Polishes Support Team
Moderator
To:Adam's Polishes Support
Jim
Best,
Jim
Best,
~3:15
BudgetPlan1 (06-30-2022)
Wolfgang Uber Sio2 rinseless wash diluted to detail spray ratio (use distilled water if you can) makes a great quick detailer. I’ve used it on two coatings and it works well. Was a FYRARMS recommendation!
FYRARMS (07-03-2022)
Jim
Best,
Jim
Best,
