MicroFiber Towels @ Costco
Popular Reply
04-16-2019, 04:43 AM
So do the CD test on these, as they can wear out very quickly and cause swirls.
The CD test is rubbing the towel on the recorded side if a CD in a single direction with medium pressure. Then look at the CD in sunlight, if you see scratches in the same line you rubbed, then it will scratch your paint.
Out of a 36 pack, I have 10 pass the CD test after two washings, than it was downhill from there.
As an owner of a detail shop I would look for an equivalent towel from the Rag Company. These have lasted me 8+ years and used on a daily basis in a detail shop. In the long run these are way cheaper, and much, much higher quality
No, these are the "Yellow" microfiber towels...at least at my Costco here in NC.
https://www.costco.com/Kirkland-Sign...100356999.html
They're a good value. I use them on my DDs and things like door jambs, engine compartments, wheels and things of that nature on the Vette.
Hawkeye56 (04-13-2019)
I've had good luck with both these yellow Costco towels and the multi-color set (orange, Yellow, Grey) that Sam's Club sells. They all clean up well and remain soft using Chemical Guys microfiber cleaner.
Yaupon (04-15-2019)
The following 7 users liked this post by Grzldvt1:
Black 03 Z06 (04-20-2019),
cadyshac (04-20-2019),
cmonkey713 (04-20-2019),
FYRARMS (04-16-2019),
LS WON (04-20-2019),
and 2 others liked this post.
I just use them on door jams,underhood and interior and thats about it. They're so cheap, I usually just pitch them when they get too dirty. I never use on the paint finish itself. I use the Rag co. Eagle Edgeless on paint finish. Hopefully the Eagle's aren't too harsh on the paint finish?!
