I have one piece of carpet that has come off on the kick panel. What type of glue/adhesive do you recommend?
3M makes a spray glue in a black can, its quite durable and I believe it can be used on carpet also. Sorry, but I cannot remember the name or number of it.
Yes 3m makes a excellent spray glue. spray on both surfaces. allow to get tacky and press together. be sure to mask off wher you do not want glue. Once you stick it is stuck so no moving around. good luck
