Polish with Rejex twice?
Received 1,029 Likes
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Just finished my first application with Rejex...man what a shine! Earlier today I washed my Vette with Dawn and looks like it's paying off. My question is this:
What benefit is there to applying a second layer of Rejex tomorrow, after the first layer cures? Can it get any shinier? Or is it just in case I may have missed a spot? Will it last longer and offer better protection against the elements out there?
Or is it a ploy by the makers of Rejex to get us to just use more product?
Thanks for your responses.....
Many people apply multiple coats of Rejex(or Zaino or any polymer). I don't think it makes the finish shine more, but it may add depth to it. I do at least two coats, mainly to cover any spots I may have missed the first time. Try it, and decide for yourself.
I have found the more layers of RejeX that are applied, the wetter and deeper the shine.
Former Vendor
As for Dawn .... leave it in the kitchen. It was never designed for car care and there is no proof that it removes all of a traditional wax, and certainly not a well cured synthetic wax (sealant). There are paint cleaners and polishes to help remove old product and prep the surface for Rejex.
I'll keep that in mind for next time.
While I'm not doubting the experts I doubt if washing your vehicle in Dawn will harm the paint. I mean we are talking about a one time deal, not every time you wash it.
Former Vendor
What I have personally noted with individuals using dishwashing liquid on a normal basis. Often times their black plastic trim appears faded or discolored. I have also seen weather-stripping that is dried out, discolored, and in need of rejuvenation. I have not seen it as notable when using a good safe car wash when needed so quickly. This might also be attributed to someone that uses specialty products in each area for best outcome and measure these areas also.
If you prefer to use Dawn and find it works in your environment, then good luck. We are not here to fight, but offer better options that meet the needs of our clients.
Dawn will not likely harm your paint when used 1-2-3 times, perhaps more. It doesn't work however... There are correct options to remove wax, sealants, and other items and unfortunately its not just dishwashing liquid. It simply removes some oils and stops beading temporarily on some surfaces. Synthetic waxes that bond with paint (like Rejex) once cured are basically immune to it under a general wash.
A couple of questions for the expert:
1.So what is a good product to use to remove wax etc?
2. Can you use polish then Rejex, or a similar product, over the polish?
Former Vendor
Rejex is a paint sealant and bonds to paint. It should be applied on a clean fresh surface without appreciable oils. If you feel your polishes or last product was oily or had silicones, you can often wipe with an alcohol/water mix also. With a little care, your sealant will lasts for many months and provide those great looks after each car wash.
In between it's nice to freshen up with something in the lines of Blackfire Wet Diamond Polymer Sealant or Chemical Guys V7. .It will add a little "pop" back and seems to prolong the longevity
Former Vendor
http://www.autogeek.net/prima-hydro-max.html
You can use a paint cleansing lotion or polish. There are commercial strippers (Acyrosol etc...) that also could be used. Paint cleaners are best used on good paint, and polishes on paints that need correction.
I'll share with you a little hidden gem I started using over sealants .... but don't kill me if you fall in love with the looks and crazy beading too.
i chuckle. thanks! i've used the Slick before-how would you compare the two and Hydro or Hydro Max. I need to order some things as I'm low on V7 .
OP -sorry to hijack
Former Vendor
Does McGuiars Ultimate Polish have anything in it that cause Rejex to not work as good? That is what I currently have on hand.
Might have to try some of that. I'm all about easy!! Got anything to keep it from raining the day after you use all these high dollar products??
I wash my three cars weekly every Saturday or Sunday morning. Living in South Florida I have not had a clean car for more than a couple hours. This rain is crazy !!!
Slick .... my wife loves that product and scent. Hydro Max looks better, has no cleaning ability at all, and unfortunately does not have as nice a scent. (not a big issue) The gloss is slick on steroids. The beading is crazy also ....
