Polishing pads
Polishing pads
So here's the deal:
I have a DA machine and want to apply a coat of rejex to a Chrysler Pacifica. I don't really enjoy waxing cars to begin with and want to let the machine do most of the work.
What pads do I need to simply apply and then remove rejex?
I have this:
http://www.harborfreight.com/6-in-va...tm_source=1040
I am not looking to do a lot of detail and finessing. Mostly I just want to apply and then buff away rejex without doing it by hand.
Former Vendor
Make sure to use a foam pad with no abrasive qualities to apply the sealant. Don't use heavy pressure or high speeds, its not needed. After it dries, consider using a MicroFiber bonnet over a foam pad to help with removal.
The Harbor Freight 6 In. Variable Speed Dual Action Polisher is not a bad entry level machine if you only use it a few times a year.
My suggestions:
IMHO DA machines work best with a 5" backing plate
Meguiars Mirror Glaze W67DA G110 DA Polisher 5 inch Backing Plate
For the extra $2-$3 dollars "Do it once. Do it right."
For Applying LSP
LC Blue Finessing Flat 5.5 inch Foam Pad
or
LC Hydro-Tech Crimson Finishing Foam
For Removing LSP
Lambswool 6 Inch Leveling Pad
use it with
Indigo 6 Inch Microfiber Bonnets 2 pack
Run slow speed 2-3 with light downward pressure.
NOTE: (Killrwheels@Autogeek I hope you don't mind a couple of links to your stuff)
My suggestions:
For Applying LSP
or
For Removing LSP
use it with
Thanks guys. I have a shopping cart going over at Autogeek.net. I went Merlinii's advice and have a 5" backing plate and several pads, as well as bonnets, selected.
