Stains on the exterior. Need Help..
Hello I have recently seen these stains ( pictures attached ) which I am not able remove if someone can help me that will be great. Its on the outside paint.. I have tried Water, soap, vinegar, baking soda.. I have read this forum and it looks maybe like hard water stains but not sure.. Any input from people will really help me..
Former Vendor
looks like tape residue ??? Is it sticky ???
Generally you would consider using an adhesive remover (if sticky), then moving to a paint cleansing lotion (which is a chemical paint cleaner) and then onto polishing (abrasive) as needed. If its hard water, several companies make water spot removers that should help also.
Can I get any water spot remover in Walmart ?
Looks like duct tape residue to me. I would try 3M adheasive remover, if that doesnt work you most likely going to have to have it buffed off as long as it is on top of the paint.
