Polishing a toilet seat!
1 Post
St. Jude Donor '03-'05-'06-'07-'08-'11-'12-'13-'14-'15-'16-'17, '21
This may be a first for this kind of question here, but I'm sure I'll get some useful information.
We just renovated one of our bathrooms, and after finishing the tile floor, I got the new toilet & vanity installed so the bathroom would be somewhat functional again.
The new toilet (Kohler) has a solid plastic/acrylic/whatever seat on it, which I managed to scatch up during the remaining work I did in the room. It's a soft-close seat, about $70, so I don't want to just replace it.
I wet sanded the top with 2000 grit wet-or-dry paper, and can no longer see any of the dings & scratches I had in it. Of course, it now has a sort of dull hazy look to it, rather than the glossy look it had when new.
Would white polishing compound be a logical next step? I have no idea how it would compare to a grit # of 2000 from the paper I used.
I plan to use my Porter Cable 7424 to polish it. Assuming I use the white compound, or something else recommended here, should I use a foam pad, a terry bonnet, or? And should I use a high or low speed?
I know it's an unusual question, but it can't be too much different than polishing a plastic roof panel. Thanks!
Location: Ponte Vedra Beach / London State: Dazed and confused
Meguiar's Mirror Glaze line M17 Clear Plastic Cleaner and M10 Clear Plastic Polish with a new foam (LC White or Black) pad to restore scratched plastic surfaces
1 Post
Thanks for the replies.
I'm not having much luck with the white compound; it seems to be leaving it's own light scratches. I'll try those Meguiar's products next.
