Product Demo: Adam's Car Wash and the Uber Foam Cannon
Former Vendor
Many have asked us to show you this set up. Take a look, Enjoy!
Products used are listed below
Adam's Car Wash Shampoo 16 oz
Adam's Car Wash Shampoo 1 gallon
Uber Foam Cannon pressure washer attachment
Kranzle K1122TST Cold Water Pressure Washer
If you have any questions feel free to ask.
What does it take to use the foam cannon and what advantage is their to it?i want to get a power washer to wash car first then do the wash pad and bucket routine....will the soap foam help remove dirt and then hit it with power washer,then wash pad?
Former Vendor
you would first foam your car let it dwell for a few minutes, let the car wash soap do the work, rinse, then follow with a traditional wash. foaming the car will remove quite a bit of the loose dirt and grime on the car hence reducing the chance of marring and swirling your paint.
Former Vendor
Great video.
Looking to buy myself a new pressure washer. The unit in the video is incredible, but incredibly expensive for the DYI-er.
Phil. What electric units do you recommend that will do a good job with a foam cannon? I had a Karcher 1500 PSI but was told this is too low to achieve a good "shaving cream" type foam. I was told 1800 psi is the minimum is this correct?
Thanks.
Steve -
Thanks.
Steve -
I would love to buy the foam cannon but I have no clue if it will work with the pressure washer I have. It's just some cheap one my mom got several years ago. How does the foam cannon attach to the pressure washer handle? Is it a quick connect setup or does it screw on?
Former Vendor
