Cleaning chrome exhaust tips
I am getting tired of polishing my exhaust tips after every track day. Polishing the outer 2 is fast enough but the inner 2 usually take 3-4 times longer and that's with using some 0000 steel wool.
I started with Blue Magic, a polish and sealant in one. They polished up nice but needed serious elbow grease to bring them back. Then I tried some Mothers polish followed by Rejex. Let that cure for ~18 hours. Stuff is outstanding on the paint but didn't hold up any better than the BM.
Can you suggest either a cleaner or polish that would cut through the exhust residue more quickly without doing any damage?
Former Vendor
I would consider a coating like G-technic . I doubt it will reverse or stop all buildup, it should however make cleanup easier.
http://www.autogeek.net/gtechniq-surface-coatings.html
Ceramic Bryte. It's the stove top cleaner you use on those glass or ceramic ranges. Just work it in with your hand and wipe off with paper towel.
Do this a couple of times.
then follow up with any kind of polish.
Plus, you sure those tips are chrome and not stainless steel?
Ceramic Bryte. It's the stove top cleaner you use on those glass or ceramic ranges. Just work it in with your hand and wipe off with paper towel. Do this a couple of times. Then follow up with any kind of polish.
SS on the tips - thanks for correction.
SS tips not chrome - my mistake.
Sorry guys but this is a dumb newbie question.I am guessing I can not get the OEM exhaust tips as shinny as these pictures because they are not OEM tips.Am I correct, because some of these exhaust tips look like glass and I can't see the stock ones that came with my ZO6 looking like that. Am I correct with this thought?
I went the PlatiDip route recommended to me by someone on the general forum. Was told it can take heat up to 315 F. They don't look as good but if it takes scrubbing them out of the equation, it will have been worth it. Did the barrels of the wheels too.
Thanks for suggesitons.
I use that Optimum polish from Auto-Geek . I also use a drill with a buffing head. You need one with a power cord as the battery pack ones drain fast.
Clif
Clif
They were totally nasty and black.
The Plasti-Dip decision was a disaster. 4 coats were seared into the center tips after 1 track day so much it turned almost into paint. It could not be peeled off. I used several different polishes with 0000 steel wool and got virtually no results. After a few hours, I tried Scott's recommendation of Cerma Bryte. I tried another ceramic top cleaner initially when I couldn't find the CB. It felt abrasive but was not better than the any of the polishes. It took another 45 minutes per tip but the CB actually worked. I still needed the steel wool but at least it worked.
I also ordered some aluminum compound in case the CB failed. The compound was better but only marginally so. At 4 times the price, I would not buy it again. I'm sold on Cerama Bryte. I am more than a little surprised it worked but happy it did.
I'm not up for trying the outer 2 tips just yet so I have the inner two back to stock and the outer 2 an abused shade of black. Going forward, I believe the CB will address my original issue quite well, namely polishing after the track .
Thanks Scott
Former Vendor
There is a product from P21S that removes tarnish, rust, and dirt easily on uncoated metal. It does however need to be followed up with a metal polish to bring back the bling-bling to a chrome like final finish.
http://www.autogeek.net/p153.html
when I got my car 3 years ago, the tips were pretty dirty. I first wet sanded them with 2000 grit sandpaper. Next, I polished them with Semichrome polish, applied with a drill and Mother's cone-shaped bit. Using the same Mother's device, I polished them with a less abrasive product (I use Zaino AIO). Lastly, I finish them with a polymer sealant ( Zaino z2 or Rejex, for example). I don't use wax because the heat of the pipes will eventually burn the wax and turn the pipes yellow.
Sorry guys but now I am mixed up.Can you get the OEM pipes that come with the Z06, shiny like some of the pictures or you have to change to chrome tips.What is the best polish for the plain basic OEM pipes? Thanks!
