I just noticed the weight in my PC says 5" max. I used 6" pads with that weight. Will the bigger weight or smaller pad make a difference on overall time correcting paint?
It may make it vibrate less. I wouldn't think it has too much effect on paint correction. I have the 6" weight in mine and don't change it when I use 3,4, or 5 inch pads. I have a couple extra 5" weights here. Thought one might be a 6" and I could send it to you.
Never found any real difference using either one with large or smaller pads. It is best to follow the manufacturers recommendation but doubt a notable difference.
