Sister in Law's NSX needs help
What would you recommend after we clay bar ?
I don't know what the previous owner did or didn't know about paint care, but YIKES
Right now - it has that "brillo fresh" look to it
I have some Pinnacle Advanced Swirl Remover + Finishing polish, but for this project, I'm not sure that will be enough to get most of the scratches out
Menzerna SIP ?
The swirls are on the entire car- best shown on the top pic
Opinions ?
Menzerna SIP ?
Opinions ?
Menzerna SIP ?
Opinions ?
Menzerna SIP ?
Opinions ?
Looking at the pic, I would go with SIP with a good orange cutting pad with a buffer. you might need to go over it twice with the SIP.
Oh, pic of Sis in law.... ;-)
Former Vendor
You will want to polish the paint and likely will want a 2-3 step process as needed. You could start with the Pinnacle polishes as typically foreign paint is a bit easier to correct. If you find it doesnt do what you like then Menzerna is a valid choice. SIP is great and 085rd is the perfect finishing polish.
St. Jude Donor '12-'13
Former Vendor
NSX paint is some the easiest to correct and make look perfect. You don't need anything more than 2 steps to accomplish this.
1- Polishing compound - HD CUT
2- Finishing polish - HD Polish
Zero duct, can be used in full sun, no fillers and very cost effective.
