Washing and drying my C5
Could you seasoned Corvette owners provide some tips as to the best way to wash and dry while protecting the finish without scratches or swirls?
Same thing as ricknyc23 said!!! I use a leaf blower first because it gets most of the heavy water build up off, then I use a meguirs waffle drying towel and it does an outstanding job with no swirl or scratching.
Received 1,675 Likes
Microfiber towels.
Try this kit, I've used it for several years now, it is a great product. You wet the vehicle, using there special soap, soap it down, using a mite wipe down the soapy vehicle, rinse, then switch to ionize rinse, this remove hard elements in the water making it pure clean water that runs off and drys without leaving spots or strains.
Saves time and works great. Good luck.
http://www.amazon.com/Mr-Clean-AutoD.../dp/B0006M56CE
I hand wash, or if being lazy I use a touchless drive through, then take her for a spirited highway run and 99% of the water just blows off.
The Rejex sealant makes the surface really slick
Best way for me..do it yourself carwash. After sun goes down.use my own micro mit and soap.only use the rinse and then the spot free.drive it home park it and in da morning its dry.no spots.spot free rinse love it.
Received 19,293 Likes
'20-'21-'22-'23-'24
I use a self serve car wash, then take the car for a quick trip down the highway to blow the water off. Once home, I use a clean Absorber to finish wiping off any remaining water.
