You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Are there any options out there for spot free rinse that doesnt cost 3 bills? The mr clean contraption looks good but it looks like they stopped making the filters for them. Or I cant find them. I also found a revolutionizer that screws on the end of garden hose that is suppose to be good for 20 washes. Anyone tried these?
The water here is hard and sucks bad. Ive got a toro leaf blower on order but I would think the spot free rinse would make the process even easier. I just dont want to spend 300 or more bucks for the added convenience. thanks for input
Mr Clean was hit or miss, you can add a filter to your hose which removes alot of the minerals that cause water spotting, or break out a bit more and get the CrSpotless System.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 10 YEARS !
So did the mr clean device stop making filters? I like the cost of the one you posted, but from reading it exchanges calcium and magnesium ions for sodium ions, which will still leave spots. Other than mr clean, there seams to not be many cheaper options. Maybe I will try the revolutionizer. If its 2 bucks a rinse, its pretty cheap considering I dont have to lay out $400 on top of this.
Any other input would be appreciaed. Im just going to use it for the final rinse, so theres got to be a cheaper way.
hihoSilver,
I can't find the thread but gparacer1 had a thread years ago with pictures on his set up. The bucket was located higher than the pressure washer so I assume gravity and the suction from the PW were sufficient. I ended up buying a CRSpotless, but this would be less expensive. You could also use distilled water and ONR - I've done that a couple of times.
Here's the PM that he sent me. "The only pics I have are the ones on that thread. But in a nutshell......I got a 5 gallon home depot bucket and got a plastic swamp cooler drain and put it on the hole I made in the bottom of the bucket. Then you get an old garden hose with the end that fits into the pressure washer and cut off about 6 feet. You connect the non threaded end to the bucket and the other to the washer. Then pour in distilled water and sometimes it takes a few seconds to prime the pump.
Hope that helps."
I already have a water softener and it is plumbed into my hoses outside as well. Will this make a CR Spotless system last longer since the calcium has already been replaced with sodium by the water softener?
certainly shouldn't hurt it, but likely still some other minerals to remove to make water as clean as possible
__________________
