BLACKFIRE Wet Diamond
Blackfire Wet Diamond All Finish Paint Protection is what I used. I first applied Wolfgang Finishing Glaze 3.0,I then topped with the Blackfire. This product is so easy to apply and remove, One of the slickest finishes I have ever felt,seen.
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
DRLC5 ... ok, I will try some of yours first before throwing any money down for my own bottle of this stuff!
wolfgang with blackfire
I have a silver vette and silver caddy and have been using wolfgang products. The paint on both is very good. I would like to do the following:
1, clay
2. wolfgang paintwork polish enhancer
3. wolfgang finishing glaze
4. Blackfire wet diamond all finish sealant
5. wolfgang fusion wax
Is this the correct order and do you reccomend these?
1, clay
1, clay
1, clay
1, clay
1, clay
Former Vendor
Excellent choice of products. However, if you are using Finishing Glaze 3.0, you do not need to use Paintwork Polish Enhancer. FG 3.0 will do everything PPE does and then some (clean AND lightly polish to a high gloss). I would Clay, FG 3.0, Blackfire, and top with Fuzion 12-24 hours later.
one is indeed a paint cleanser the other a polish, really dont need both but if desired it would be in reverse order.
Tried the Zaino process several times and then tried Blackfire Wet Diamond. All I use now is Blackfire....easy application...easy removal and shines as good as Zaino and not nearly as tempermental!
Does Blackfire seem to care which prep product you use as far as bonding goes? I like to use PB Black Hole Glaze prior to my old sealant (PB EX-P) but I've been tempted to switch sealants after seeing such great slick/wet results with the Blackfire
#33
Former Vendor
you will be fine, have heard of no compatibility issues between the two. Many love the Poorboys glazes as they are sealant compatible, and Blackfire should just add to it with even greater good looks.
#37
Blackfire says it can be topped with wax, doesn't say what brands, so I assume it will be fine.
That said, I've topped Blackfire with Megs. wax and a few others, can't see a difference or any improvement, so IMHO, no need to do anything over it.
Correct the paint, apply Blackfire and enjoy, your done.
#38
Former Vendor
It can indeed be topped as desired, the obvious choice would be Blackfire Midnight Sun its carnauba based counterpart. No matter the choice in wax topper, just make sure its a pure nuba wax with no appreciable cleaners or polishes. Pinnacle, Dodo, and others exist too.
#39
I just polished, sealed with Black Fire and topped it off with Pinnacle Souveran wax and it looks fantastic. The sealant gives the car the sharp, shiny look, and the carnuba on top gives it that wet, soft glow. Love it.
