Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
New Product: Meguiar's Pad Washer!
Old 09-23-2011, 01:57 PM
Nick@Autogeek
Nick@Autogeek's Avatar
St. Jude Donor '12
Default New Product: Meguiar's Pad Washer!
You asked for it, and Meguiar's delivered! We're very excited to announce that we have the Meguiar's Pad Washer in stock and ready to ship. No longer will you have to clean pads by hand and deal with the mess associated with it. With the Meguiar's Pad Washer you can clean any type of pad with any polisher, dual action or rotary.
The Meguiar's Pad Washer consists of a durable 5-gallon bucket equipped with a grid insert supported by springs. Cleaning pads is as simple as adding a pad cleaner such as Detailer's Pro Polishing Pad Rejuvenator and pressing the pad against the grid insert with the machine turned on. Cleaning solution is pumped into the pads while you press the pad against the grid insert. An adjustable splash guard keeps all the cleaning solution inside the bucket so there is no mess. The Meguiar's Pad Washer also includes a watertight lid so you can transport water and cleaning solution on the go.
Here is a picture of Jason Rose, Field Marketing Manager for Meguiar's Professional Products demonstrating the pad washer using a G110v2 and a Microfiber Cutting Disc.
After a quick cleaning the Microfiber Cutting Disc is ready to remove unsightly swirls and water spots from another panel.
For the best performance of your foam or wool pads, it's critical to clean them often. The Meguiar's Pad Washer is a huge time saver and should be a must have for any professional detailer.
Quick Reply: New Product: Meguiar's Pad Washer!
