Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-26-2011, 10:20 PM   #1
shank0668
CF Senior Member
shank0668's Avatar
Default Scratch Removal?
Today a dog jumped on the vette. I am curious what a good scratch remover is. It isn't into the paint, but certainly a pretty bad scratch. You can feel it with your nail.
Click the image to open in full size.
shank0668 is offline   Reply With Quote
Old 07-26-2011, 10:27 PM   #2
goober51
CF Senior Member
yeah, the friggin' cat next door scratched my hood..I am interested to find out also
goober51 is offline   Reply With Quote
Old 07-26-2011, 10:47 PM   #3
shank0668
CF Senior Member
shank0668's Avatar
That sucks, last year there was a dog or car on the hood.
They aren't very deep, and can barely feel them with my nail.
Old 07-26-2011, 11:14 PM   #4
BLK281
CF Senior Member
BLK281's Avatar
Good news and bad news.
Good news is the scratch will come out...bad news is you won't do it without a buffer.
BLK281 is offline   Reply With Quote
Old 07-26-2011, 11:56 PM   #5
diablojota
CF Senior Member
Wetsanding it will most likely remove most of the scratch. However, I would suggest trying it with some Meguiars 105 on a yellow or orange pad at high speed with your DA buffer. This will make it look far less visible. However, even with wet sanding, it may not get rid of it altogether, and a respray will be the only fix.
diablojota is offline   Reply With Quote
Old 07-27-2011, 12:05 AM   #6
duramaxsky
CF Senior Member
duramaxsky's Avatar
I did one like that backing my truck with the hood up. Hit the garage door opener connector. It came out with careful wet sanding and my DA with Adams products. I know where it is and can find it with a light but others who saw it unpaired can not find it. If its not through the clear you may be able to fix it.
__________________
Support the 2nd amendment because;
when seconds count the police are only minutes away!
1998 Black C5 Coupe
2008 JSB C6 Vert
2003 Chevy 2500HD diesel Arrival Blue
duramaxsky is offline   Reply With Quote
Old 07-27-2011, 12:24 AM   #7
shank0668
CF Senior Member
shank0668's Avatar
Sadly I do not have a buffer, this is all I have. http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I have a friend with some sort of buffer, Ill have to ask him about it, not sure if it is like what I have or a real one.
Old 07-27-2011, 01:20 AM   #8
diablojota
CF Senior Member
You may want to find a local detailer of some repute. They will have the appropriate tools to solve this. If they aren't very deep a good compound will probably be enough and follow that up with polish. I'm not familiar with your equipment, so I can't say if it would be safe to use with the proper pads.
Old 07-27-2011, 06:32 AM   #9
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
TOGWT DetailProfessor
Deep Scratches
A surface scratch that will `catch' your fingernail is approximately 0.04 Mil (1.0 µ) deep will usually require wet sanding (you should sand the scratch to bare metal because the device that caused this scratch was probably used with enough pressure to damage both the paint and the primer) and the clear coat refinishing
Removing a scratch requires removing the layer of paint that contains the defect; you need to level the paint to the lowest point of the scratch. Removing more that 0.5 mil (12µ) of clear coat will cause premature paint film failure as UV protection percolates to the top of the clear coat. Check paint film thickness with a Paint Thickness Meter (PTG) before you attempt to remove
As you go over a deep scratch, the abrasives round off the edges of the high spots of the scratch. The result is a shallower scratch (when no full correction can be made) rounded edges don’t reflect light the same way a sharp edge will and is therefore less noticeable.
It may be necessary to carry out some localized wet sanding to facilitate full removal of any deep scratches, once again, paint thickness must be checked, and if the paint is too thin wet sanding is NOT an option.
Once you have levelled the scratch apply paint in ‘layers’, by applying a coat of paint and then allowing it to dry, apply paint, and etc. Apply paint until it’s higher than the surrounding surface and then polish level.
Note: metallic paint is very difficult to match as the flakes won’t ‘lay down’ like OEM applied paint.
TOGWT is offline   Reply With Quote
Old 07-27-2011, 12:44 PM   #10
wysiwyg
CF Senior Member
I've had success using m105 by hand to remove scratches.
wysiwyg is offline   Reply With Quote
Old 07-29-2011, 01:27 AM   #11
xsalvioutlawx
CF Senior Member
xsalvioutlawx's Avatar
Send a message via AIM to xsalvioutlawx
That does not look bad. I had a few of those scratches that I buffed out with some polish and a buffer.
xsalvioutlawx is offline   Reply With Quote
Old 07-29-2011, 09:17 PM   #12
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
http://www.autogeek.net/dual-action-polisher.html
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
FORUM VENDOR FOR MORE THAN 10 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Reload this Page Scratch Removal?
Tags
c5, c6, cat, corvette, corvettes, corvettescratchrepair, forum, forumcar, removal, remover, repair, scratch, scratched, scratches, top
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
