Microfiber or Cotton Cloth
I usually dry my car with a microfiber towel and remove wax with a cotton polishing cloth. Now I see they are selling microfiber cloths for removing wax. Do they work well or am I better off using cotton cloths ? What do you use ?
Micro Fiber or Cotton
Micro fiber, waffle weave for drying. There are several combinations for wax removel or detaling. You might want to consider looking at the Auto Geek website under Cobra microfiber towels. Lots of good information there. Your paint will thank you.
Former Vendor
MF towels are indeed much easier to find now that true 100% cotton towels. MF towels do need to be kept seperate, and washed seperate for best results. There are several different designs depending on the area being worked on.
http://www.autogeek.net/mictow.html
Location: Ponte Vedra Beach / London State: Dazed and confused
Removing Wax / Sealants
The polyester and polyamide content of Microfiber is typically; a blend of 80% polyester (a scrubbing fibre) and 20% polyamide (an absorbing fibre).The nature of this yarn is that it is an absorbent; the reason polyester appears to absorb liquids is the many thousands of micro fibres that collectively encapsulate, this is what makes them so good at cleaning.
a) A Microfiber towel - made from polyester/polyamide will remove product, as they actually lift the dirt or wax from the surface you are cleaning and then store the particle or liquid in the towel until it is washed. due to its inherent properties (that’s why they are so good at cleaning without the use of chemicals). The polyester and polyamide are combined during weaving to create microscopic loops, which form a network of tiny hooks, scrubbing away dirt and grime while trapping it within the weave.
These very fine fibres have little 'hook like claws' that reach into the tiniest of crevices, pulling out dirt, dust, grease, grime, and even bacteria. They hold these foreign materials in their web of weaves until they are washed in warm water where the fibres relax and release these materials.
Conversely the same attributes that make Microfiber so good at cleaning have an adverse affect when applying wax. A polymer sealant forms a molecular bond with the paint surface, so when you remove it, you are removing excess product. An organic wax however, doesn’t form a bond with the paint surface but merely adheres to it, forming a chain-link type coating. A micro fibre cotton towel will leave enough of the wax behind to enable it to form a surface coating.
I can't say enough about cotton towelling for removing organic waxes. For some cotton towelling is a thing of past. But for many of the required tasks involved with the application or removal of organic waxes cotton seems to me to be the ideal choice, I just couldn't find anything that could out perform an all-around old fashion 100% cotton towel.
b) Cotton Towel - high thread count, 100% cotton micro fibre detailing towel with terrycloth weave, spun with long staple cotton and then woven into 100% natural looped terrycloth or velour, the larger fibre loop size that makes up the towels nap are trimmed to produce a fine nap, ideal for buffing and leaving behind a coating on the paint surface. Note: a terry weave towel has slight abrasive ability, which may be useful with some cleaning products
Be cognizant of the material (s) used to bind the edges of the towel (Microfiber or 100% cotton) These are much more likely to cause surface marring than the towel itself, the solution is to ensure they are paint friendly or remove the edge binding
MF would be better for a sealant (BWD, REJEX, Z5)
Cotton for Carnuba (PS, Meguiars Gold)????????
a) A polymer sealant forms a molecular bond with the paint surface, so when you remove it, you are removing excess product.
b)A 100% cotton towel will leave enough of the wax behind to enable it to form a surface coating.
