Ever try this?
Ever try this?
Went to a flea market today and saw this thought i would try it any one else tried it? http://envycare.com/index_html
Former Vendor
With out any first hand knowledge I definitely cannot speak about that product's performance.
I have used some of the waterless products on the market, many of which are re-labeled versions of the same product. The only one I have found that works well (so far) has been Optimum Polymer Technologies Opti-Clean.
This isn't to say this product isn't good, but Optimum has set the standard in using polymer technology to safely remove dirt/grime with out scratching. That said I still wouldn't use it on a heavily soiled car for fear of creating scratches/swirl marks.
Former Vendor
I will only add that whats cool about these smaller lines is an ability to try something different. Sure they dont always work as well as hoped, or seem quite similar to other products but every now and then you come across something truly special. The real challenge then becomes can you get it again once you run out.
