Anyone use Simple Green to detail their engines?
Hey guys,
I have been using Simple Green to detail my engine for years with excellent results; however, I am reading more and more negative things about it. Apparently, a lot of people don't recommend it for engines??? Does anyone know anything about this? Is it just bogus?
Thanks!Ray
Thanks!Ray
Never had an issue...light mist....rinse off. Been doing it for years.
I have seen simple green haze and discolor metal before. There are better and safer products to use. P21s Total Auto Wash, Eimann Fabrik, Meguiar's APC+, etc.
Have Used
I have used it and have no negatives. It seems to work fairly well. It is likely safer to use than some of the engine degreasers out there. It's bio-degradable for those that care. Any engine clearner that I use I rinse off with a low pressure (1200 psi) power wash (take care around electronics) and dry down with my Masterblaster.
Don't have the bottle handy but I think there is a warning not to use it on certain metals (might be alum.) You have to read the small print if I remember right. It has never given me a problem however but I have stopped using it because of the warning.
Location: Ponte Vedra Beach / London State: Dazed and confused
http://consumer.simplegreen.com/cons_faqs.php
Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminium items for over 20 years. However, caution and common sense must be used: Aluminium is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All-Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminium surfaces should be kept as brief as the job will allow - never for more than 10 minutes.
Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminium cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
One should never assume that aqueous solutions could be disposed of down the drain. Your local water treatment authority or publicly owned treatment works (POTW) will have information on treatment and disposal of these cleaners. Adjustment of pH and dilution are usually required before disposal to a drain.
Simple Green is corrosive and will react with bare aluminium causing hydrogen embrittlement (this is also known as stress cracking corrosion). As the cleaner gradually ferments it reduces the pH from its normal mildly alkaline state to acidic. Slow corrosion of the aluminium results, generating a little hydrogen on the surface.
Anaerobic conditions also generate hydrogen and hydrogen sulphide bio chemically, producing small amounts of methane. The aluminium probably has sufficient residual stress to be susceptible to hydrogen stress cracking, and this can be accelerated by the sulphide.
A ‘safer’ alternative Simple Green® Aircraft & Precision Cleaner - http://industrial.simplegreen.com/ind_prod_ext_mor.phpMeets Boeing Specs –D6 – 1748-7P (Water - based, no Hydrocarbon solvents)
Received 4,565 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Simple Green is a great product for cleaning off grease and grime.
Just keep it away from Aluminum. It will discolor it and may cause deterioration with long term use.
