Rejex ROCKS!
1 Post
Rejex ROCKS!
Used Rejex for the first time tonight on by Z06. I think I found a new friend!
Yes, I know the car is in the garage and not out in the sunlight...but in Missouri...there is no sunlight...2-4" of snow forcast for tomorrow. Gona have to wait for the sunny day pictures.
Former Vendor
we took on Rejex for our forum friends and it sells very well with the Vette crowds and for good reason. Easy to apply, easy to remove, durable and can be used on just about every surface.
Rejex Rocks Indeed !!!
Car looks super, and you are correct Rejex Rocks!
Rejex at Corvette Museum? Help
Can I apply Rejex over the top of whatever the Museum uses to present my car to me? I'm told it is "C....something", but NOT wax. I'm afraid to take the long road trip to AZ w/o something on there. Bad experience w/new cars w/o sealant or wax. Thoughts?
Former Vendor
I personally would strip the paint sealant from the factory once you get home with a paint cleansing lotion or polish (abrasive). I would then add two coats of Rejex allowing 8-24 hours between coats to all sealant to bond completely. You'll be good for months and months.
Bottom line is, like Mike Phillips says, find something you like and use it often.
I have been a faithful follower of RejeX for over 5 years. Never disappointed. Stuff works great.
1 Post
For those who have been using Rejex for a while I have a question.
The bottle says thin coat let it dry to a haze and wipe off.
Did I wait to long to wipe it off....cause it didn't just wipe off. I would do 2 sections and when done with the second would go back and start removing it. Not as bad as a carnuba wax but sure didn't just wipe off either. I ended up taking one mico to wipe off the majority then a second fresh one to buff. Any suggestions?
My guess would be you applied a bit too much. You really have to be careful and apply a really thin coat almost to the point that you can barely see it. I have done my Vette using the same process you have and no problems with removal, so that is why I am guessing you applied too much or to thick.
For those who have been using Rejex for a while I have a question. I assume also that it was dry to a haze before you attempted to remove if not than that is your problem.
Former Vendor
