Meguire's removal help
I used the swirl remover and it is very difficult to remove. When I rub very hard I just put scratches back on the clear. car is black and has many swirl marks from age.
You would have much better results with their newer products like SwirlX or Ultimate Compound.
To remove the stuck on polish you can simply apply some of the #9 to a foam applicator and go over the area a little and then immediately wipe it off.
Typically #9 should be rather easy to remove so it is possible you over worked it or allowed it to dry before removing.
Rasky
Also, check out the info on Autogeeks web page or, since you are using Meguiar's products, their forums...LOTS of great info on both with moderator assistance...
Or, call the 800 # on the Meguar's products and talk to a tech.
Former Vendor
thanks for the referral above ... sounds like Rasky's got you under control for now. If we can assist with your future Megs needs or hints please ask. Mike did a great writeup on the Megs polishes recently.
http://forums.corvetteforum.com/car-...-products.html
