CAR CARE INFO PLEASE? How to clean Chrome C1
Hello,
I just bought a c1 vette. I am looking for cleaning products.
How do you clean the white walls? I have used Bleech White but it looks like all the white is going to come offf the tire if I use it. Any suggestions?
Also how do you clean the chrome? Whats the best product to use? At the stores I see whell cleaner but no CHrome cleaner. I do not like the polishes? Is there a spray I can use that does the job?
Also how would you go about cleaning the inside? the vinyl, dash, etc. I am new to this and am taking the car to a show this weekeend.
THanks for your help in advance.
Received 4,574 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Hello,
If your chrome is in excellent condition it does not need any abrasives to maintain it. I spritz it with Z6 for regular touch-ups. (Z6 is like a spray detailer with some minor cleaning capabilities.)
Hello,
Former Vendor
DP Cleanse All is amazing on whitewalls. It's also great on the rest of the rubber as well. Really gets them clean.
Griot Garage has a nice spray on Chrome Wheel Cleaner
DP Total Interior Combo has a great cleaner and a protectant to make the interior look like new.
Hello,
Clif
Former Vendor
I am not sure what brand of white wall tires you have as I don't have a lot of experience with the various reproduction companies, but I would first contact the makers of your tire and find out if it is natural white rubber or a painted on stripe. This could explain the reason why you are getting transfer on your rag.
If it is a painted on stripe and it has aged to the point that a solvent based cleaner is removing it (and it looks dirty) it is probably stained. Try a mild household product, like Dawn, and an old toothbrush. Gently brush an area and see if you can clean some of dirt with out removing the paint/dye. If you cannot clean the tire without removing any dye, then it is stained and probably needs to be refinished.
If it is a natural white rubber tire, then I would ask the manufacturer specifics on what is recommended for cleaning. I would imagine that stronger solvents would be fine and help clean the tire (including bleach white).
If your chrome lacks that brilliant luster, then you will need a light polish to restore the luster before applying the Blackfire Wet Diamond All Metal Sealant. For chrome I really like Wenol's metal polishing twins. These are non-abrasive (non aggressive) metal polishes so they will deep clean the metal with out removing the thin chrome plating.
The Chrome on this C1 was polished with Wenol.
If chrome is badly scratched (hazy), pitted, or has dull spots where the chrome is thin, then re-plating is the only way to restore that luster. Once you have the chrome looking it's best, keep it protected, and clean as normal.
If your vinyl is clean looking, and you just need a light clean up, then a damp cloth will work great. However if there is some soiling in the grain of the vinyl and you are trying to make it look its best for the car show, then you will need a little more aggressive approach.
Since we don't know exactly what you are working with, start with the least aggressive process you can and work your way up. I would start with an old toothbrush and just (a mist of) water, and gently clean a test spot in an inconspicuous area. Wipe dry with a towel and look at it, checking to see if you removed any dye. Look at the spot you cleaned and see if is noticeably better. If it isn't cleaner and you haven't removed any dye, then I would slowly add a little all purpose cleaner to your water.
For this I would recommend Optimum Power Clean (which would also work well on your tires!) and a multi purpose graduated spray bottle for the water/mix. This way you can measure the dilution as you go. I would start with 10 parts water to 1 part Optimum Power Clean at first.
Clean and inspect, and increase the dilution as necessary to achieve the cleaning power you need but always check to make sure you are not removing dye.
After your vinyl is cleaned to the condition you want, then you are going to want to add a protectant to it help prevent future soiling and help block UV rays.
Areospace 303 Protectant is really perfect for this application.
Congratulations on the purchase and I know we all look forward to seeing the pics!
