Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Remove Wax Residue
Old 05-06-2010, 03:21 PM
Sandman93
Sandman93's Avatar
Default Remove Wax Residue
I had my Z06 professionally detailed and they really did a great job. However, after I got hit in a rain storm I noticed that there is a white wax residue on my side door panels.
What is the best way to remove the wax residue? I went over it with the Adams VRT but it wont go away after the VRT dries or get caught in the rain.
Ive heard that rubbing alcohol works with a micro-fiber towel?
Your thoughts or suggestions?
Old 05-06-2010, 03:39 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
A detailing/cleaning spray usually works for me, or you could put some diluted car wash soap into a spray bottle, let it soak for a little bit and wipe it out with a soft cloth/sponge.
The VRT stuff is most likely for top-coating, not for cleaning.
Old 05-06-2010, 05:40 PM
NORTY
NORTY's Avatar
Methylene Chloride will remove wax. ANY WAX or polymer. Just don't breathe the fumes...
Old 05-06-2010, 05:51 PM
intheboost
intheboost's Avatar
50/50 isopropyl alcohol (rubbing alcohol) / water mix should work.
Old 05-06-2010, 05:54 PM
383vett
383vett's Avatar
Received 1,542 Likes on 1,043 Posts
Have the detailing place restore the surface. That's what you paid them to do in the first place.
Old 05-06-2010, 06:45 PM
WPaul
WPaul's Avatar
Methylene Chloride, also known as DICHLOROMETHANE, is the active ingredient in paint stripper
Drys very fast,,cold to the touch,,has been used in the past as a Freon type product for cooling.
NOT to be put on a painted surfaces Is a carcinogen
STAY AWAY from this stuff
Old 05-06-2010, 06:48 PM
Onyasix
Onyasix's Avatar
Old 05-06-2010, 07:10 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
peanut butter ...really !
Often times a soft paint brush, can help remove dried wax if stuck in a crack. You can also find commercial wax removers like Wax Blaster.
Old 05-06-2010, 09:08 PM
Sandman93
Sandman93's Avatar
Default Thank you
1. Right off the bat I will try the Rubbing Alcohol..
2. I asked the guys who detailed the car and they said it was there before they started... IMO no need to get into a pissing contest. Rather take the high road.
3. I will purchase the Wax Blaster which was also a great idea.
Old 05-06-2010, 09:17 PM
Sandman93
Sandman93's Avatar
I just went to your website to order it and it says its on back order? Any way you can get me a bottle? PM if you can.. thank you
Old 05-06-2010, 09:24 PM
rbrcs
rbrcs's Avatar
If the deailter gave you that kind of answer, I would think twice before going to them again.
Old 05-06-2010, 10:03 PM
Sandman93
Sandman93's Avatar
That wasn't even a consideration after I saw the wax.
Old 05-07-2010, 01:40 PM
Former Vendor
I dont have any personal stock (offsite) but likely back as soon as possible. Till then, try the paintbrush/toothbrush if in cracks. Likely either old wax or dried polish.
Old 05-07-2010, 06:42 PM
wolfdogs
wolfdogs's Avatar
Location: Stafford VA, home of our wolf den. No house break ins to date.
peanut butter works.. also Wesson oil!!!
i dont have "wax residue" anymore, thanks to ......................... yall know... LOL
Old 05-07-2010, 08:35 PM
TOGWT
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Methylene Chloride will remove paint [wax]. ANY paint WAX or polymer. Just don't breathe the fumes...
Old 05-09-2010, 09:50 AM
JJU
JJU's Avatar
Cruise-In II Veteran
Stay away from Methylene Chloride. There are easier/better ways to remove old wax. Depending how "caked on" it is, peanut butter will work and so will Dawn Dishwashing Soap (as an example) in that it will soften up heavier "applied and dried" amounts.
I just finished detailing a triple black 1999 vert with Zaino.
Owner is now convinced to stay away from carnauba-based products PERIOD because of this problem after I showed him how good his car can look. I used a soft tooth brush with some bristles shaved off to get in to the cracks between panels and Body Side Molding.
Old 05-16-2010, 07:37 AM
DevilDog II
DevilDog II's Avatar
Oldtimer
I never thought of that. You can kill two birds with one stone. You can detail your car and have lunch at the same time.
To Remove Wax Residue
Old 05-16-2010, 08:38 AM
dvilin
dvilin's Avatar
Received 7,931 Likes on 4,811 Posts
Old 05-18-2010, 10:30 AM
hb4lthr
hb4lthr's Avatar
Originally Posted by dvilin
Just don't put it on the car first and then spread it on your bread
Old 05-20-2010, 01:43 AM
Licit
Licit's Avatar
That was a really unbelievably shoddy answer from the detailer. Sounds like they don't even care that they are admitting lack of dealing with an area that needed treated.
Quick Reply: Remove Wax Residue
