Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2010, 08:08 AM   #1
dealrocker
Junior Member
Default Cloudy Headlights
My friend has cloudy headlights..! Read somewhere it is caused by oxidization and road grime build-up. Cleaning cloudy headlights is very important for safety purpose. Looking for the safe and easy way to remove oxidation from headlight without risking damage to the protective ultra violet layer. Planning to hit Auto Parts Warehouse this weekend to check out some useful products.
Any advice and suggestions are welcome.
dealrocker is offline   Reply With Quote
Old 01-18-2010, 10:00 AM   #2
capevettes
CF Senior Member
capevettes's Avatar
I have used the following 3 products with some success on cloudy headlights:
1. LP Aero Plastics Inc. acrylic polish and sealant. It is used in the aircraft industry for windshields/hard plastic/plexi-glass. (Aero Plastics Inc Jeannette, Pa.)
2. Zaino Plastic Magic cleaner and polish. (Zaino Bros.)
3. Meguiar's Plast X. Available in most auto parts stores.
capevettes is offline   Reply With Quote
Old 01-18-2010, 12:07 PM   #3
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Methodology
• Use a solvent type cleaner (Klasse or Zaino All-In-One) if this does not remove the oxidation use a plastic polish
• Prior to application of a plastic polish ensure that the area is clean and free from dust particles by washing with a soft cloth and warm water.
• It is not advisable to use harsh cleaning detergents on plastic.
• Shake the bottle thoroughly. Plastic polish can be hand or machine applied
• Tape-off all around the lenses so that you don't accidentally wet sand or buff the surrounding areas.
• Using a random orbital buffer with a 3.5-inch backing plate and a 4-inch (Lake County (LC) White) polishing pad or a terry cloth applicator
• Place a small dab (about ½-inch diameter) of plastic polish on the foam pad or applicator.
• Place the pad on the lens surface and turn on the machine (speed #4)
• Polish the lens repeatedly in a left-to-right and an up and down pattern.
• Continue polishing until all the polish is gone
• Wipe the lens with a damp Microfiber towel
• Inspect the lens, repeat the polishing process 2-3 times as necessary
• Plastic polish will not remove clarity defects that are within the plastic but it will remove external/surface scratching and ultra violet (UV) oxidation (yellowing)
TOGWT is offline   Reply With Quote
Old 01-18-2010, 03:09 PM   #4
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
http://www.autogeek.net/meguiars-pla...light-kit.html (megs)
or
http://www.autogeek.net/plastik-lens-cleaning.html (our Wolfgang Kit)
or
http://www.autogeek.net/diamondite-clear-plastic.html (Diamonite)
each of these kits offers a way to repair headlamps and certainly remove some oxidation that discolors those plastic lenses. Use couponcode CORVETTEFORUM on checkout and save 10% more on these prices. If you need more help, under the Diamonite page there is a how-to section for headlamp repair also.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 01-19-2010, 12:19 PM   #5
meghan@autogeek.net
Premium Supporting Vendor
meghan@autogeek.net's Avatar
Great Video for some help on cleaning them.
http://www.youtube.com/watch?v=1_JfuS8MZM4
meghan@autogeek.net is offline   Reply With Quote
Reload this Page Cloudy Headlights
Tags
2005, c6, caused, clean, cloudiness, cloudy, corvette, dealrocker, foggy, hazy, headlight, headlights, klasse, photos, polish, remove
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
