Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-17-2010, 10:44 AM   #1
GREGG-73
CF Senior Member
GREGG-73's Avatar
Gregg Plapas
Default Porte Cable 7424XP Polisher ??????
It was recommended I re-post my thread here, please see the link below...
http://forums.corvetteforum.com/c3-g...-buffer-s.html
Thanks,
Stay in tune....
GREGG-73 is offline   Reply With Quote
Old 01-17-2010, 11:56 AM   #2
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
Micromarring and smaller scratches can indeed be removed and lightened with the use of a machine buffer like the PC-XP. You always want to start with the lightest polish and pad combo and move more aggressive only as needed.
If you have the Wolfgang/Lake Country pads then likely a white pad (medium) and Zaino ZPC will be a light combo and should help. You can always move to a more aggressive polish (often called swirl removers and numbered based upon cut) or to an orange (abrasive) pad. I have never used an orange pad and ZPC so would suggest speaking with Frank (aka AgentF1) or Sal first to get best hints. Other polishes like Megs 105, Menzerna SIP, and even 3M should work also.
Often times when using a more abrasive pad/polish combo you need to come back to a lighter pad/polish combo to remove smaller markings and micromarring. While it doesnt sound like you are in this predictament now, it might be needed later. If the marking is quite light and really just want to clean paint a bit and boost the gloss and reflection then move straight to a finishing pad and light finishing polish.
http://www.autogeek.net/detailingtips.html
(this should help too , and please contact us if additional help is needed).
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 01-17-2010, 02:35 PM   #3
GREGG-73
CF Senior Member
GREGG-73's Avatar
Gregg Plapas
Thank's much...I think I am going to try the Menzerna SIP, and buy a claybar....and then do side by side panels for the best / desired results.
Stay in tune.....
Old 01-17-2010, 06:26 PM   #4
blackmachdown
CF Senior Member
blackmachdown's Avatar
Send a message via AIM to blackmachdown
Quote:
Stay in tune.....
a claybar isn't going to remove micromarring that your talking about, all its going to do is remove above surface contaminants. If you get too agressive of a claybar you might even add more micromarring
blackmachdown is offline   Reply With Quote
Old 01-17-2010, 06:51 PM   #5
0zoomzoom mazda5@properautocare.com
Former Vendor
I would go with the M105 and M205 combo on your Corvette. SIP works ok but it has fillers that will make you think you have remove them.
zoomzoom mazda5@properautocare.com is offline   Reply With Quote
Old 01-17-2010, 08:59 PM   #6
Stay in tune.....
great choices indeed. Claybar is a must before polishing IMO and really only needs to be done annually on most finishes. SIP is a bit more aggressive than your current polish but finishes down quite nicely. On the first panel or two you can wipe with alcohol as desired to test and make sure the correction worked. With the lighter markings you suggested, SIP should indeed help. Let me know if I can be of more help and thanks for considering Autogeek.
__________________
Old 01-18-2010, 07:59 AM   #7
GREGG-73
CF Senior Member
GREGG-73's Avatar
Gregg Plapas
Quote:
Originally Posted by zoomzoom [email
mazda5@properautocare.com[/email];1572787228]I would go with the M105 and M205 combo on your Corvette. SIP works ok but it has fillers that will make you think you have remove them.
Can you tell me whom makes these products and where to purchase them as well. I'm sorry, I am not familiar with these numbers, and I am heading into uncharted waters.
Stay in tune....
Old 01-18-2010, 03:03 PM   #8
We also carry the Megs line , the numbers indicate the two polishes with SMAT technology. Essentially they use non-diminishing abrasives so they continue to cut and correct as same level from start till finish.
http://www.autogeek.net/meguiars-mir...-compound.html (105)
http://www.autogeek.net/meguiars-finishing-polish.html (205)
http://www.autogeek.net/meguiars-swirl-remover-kit.html (kit with both products)
Old 01-19-2010, 08:49 AM   #9
GREGG-73
CF Senior Member
GREGG-73's Avatar
Gregg Plapas
Thank's......
Stay in tune..........
Reload this Page Porte Cable 7424XP Polisher ??????
Tags
105, 7424xp, cable, greg, m205, meguiars, menzerna, pad, parts, plapas, polisher, porte, sip, white, zaino, zpc
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
