Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-11-2010, 05:54 PM   #1
arkus
CF Senior Member
arkus's Avatar
Default Menzerna Power Gloss
I traded my 04 white vert on a red 04 vert . The red vette has moderate swirls . I tried SIP and it did an ok job . I want all of the swirls out .
Is the power gloss too agressive with an orange pad ?
arkus is offline   Reply With Quote
Old 01-11-2010, 06:16 PM   #2
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Hard to recommend a polish to remove scratches until they are seen, but a '1-step polish may be a remedy (Power Finish with an LC Orange foam pad) -
Power Finish (PO203S) - (M) this is a one-step scratch remover polish is formulated for CeramiClear or other ‘Hard’ paints. It will remove 2500 grit, cut 3.0-gloss 3.5, is formulated as a quick way to polish out light flaws and amplify the paint’s gloss. Use a primed Orange (mid range, high density foam (60 PPI) medium abrasive cutting action LC CCS foam pad 1200 RPM
With a single step polish once you see it has just started to break-down, either clean your pad or replace it with a fresh one and then continue at the same RPM you left off at, break-down the rest of the polish, and then continue to burnish the paint surface. After a wipe-down process it can be followed with Nano Polish (PO85RD 3.01) using a black pad for lighter imperfections, or for burnishing the surface for even more depth and gloss.
While technically a final or finishing polish in the same category as PO106FA, PO203S Power Finish offers substantially more cutting power, In fact, it is just below MenzernaPO83 Super Intensive Polish in its ability to remove moderate to mild swirls, water spots, and light scratches, and then it burnishes the paint to an ultra high gloss.
Try the LC Orange pad with Menzerna Power Finish 203S first and if that doesn’t rectify the problem proceed to Menzerna Power Gloss on LC Orange foam and then clean up with Menzerna Power Finish on LC White foam.
PO203S finishes down LSP ready on light colours but would suggest PO85RD is needed on dark colours.
TOGWT is offline   Reply With Quote
Old 01-11-2010, 06:29 PM   #3
arkus
CF Senior Member
arkus's Avatar
I'll give it a try . I've always had great luck with Menzerna products
Old 01-11-2010, 08:10 PM   #4
steve8
CF Senior Member
steve8's Avatar
What polisher?
steve8 is offline   Reply With Quote
Old 01-11-2010, 08:47 PM   #5
arkus
CF Senior Member
arkus's Avatar
Flex
Old 01-11-2010, 08:53 PM   #6
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
PowerGloss is a dedicated compound within the Menzerna line. Its much more abrasive than SIP even without the ceramiclear abrasives. PowerFinish IMO is about the best one step polish you will find, does the work of SIP/Nano in most settings. Not sure it would be considered more abrasive than SIP initially however and sounds like that is where you want to go provided you havent already moved to orange pad/SIP first.
http://www.autogeek.net/menzerna-of-germany.html
(chart on page shows polishes and where each fall in category)
Killrwheels@Autogeek is offline   Reply With Quote
Old 01-11-2010, 09:01 PM   #7
arkus
CF Senior Member
arkus's Avatar
I'm using the smart orange pads with SIP now and want to move to Power Gloss with the same orange pads.
Old 01-11-2010, 09:09 PM   #8
Quote:
you could start with white and move to orange as needed. With orange and Powergloss (likely even white and Powergloss) you will need to come back down and remove some micromarring and really gem the paint to bring out the reflection and gloss. SIP, PowerFinish, perhaps even Nano would work well afterwards. 085rd for jeweling as desired with a finishing pad.
Remember least abrasive method, then moving more abrasive only as needed. Megs 105 would be a substitute if you wanted a compound and didnt mind moving from the Menzerna line for it.
Old 01-11-2010, 09:40 PM   #9
arkus
CF Senior Member
arkus's Avatar
I have some 105 but it seems to dry so fast , I'm not sure I'm doing it right so I went back to Menzerna
Old 01-11-2010, 10:03 PM   #10
0zoomzoom mazda5@properautocare.com
Former Vendor
Go with the Meg's M105 and when compounding have a small spray bottle of water to just give a little spray of water on the surface and it will go further when using your Flex. And take those swirls out!
zoomzoom mazda5@properautocare.com is offline   Reply With Quote
Old 01-11-2010, 10:45 PM   #11
arkus
CF Senior Member
arkus's Avatar
I'll try that .
Would quick detailing spray work too ?
Old 01-11-2010, 10:52 PM   #12
Former Vendor
I always had use good old H2O which is very very cheap, but a QD should work also.
Old 01-12-2010, 12:06 AM   #13
arkus
CF Senior Member
arkus's Avatar
thank you
Old 01-12-2010, 03:16 AM   #14
arkus
CF Senior Member
arkus's Avatar
I tried the 105 and it did the trick . Wonderful results
Old 01-12-2010, 04:39 AM   #15
TH0001@properautocare.com
Supporting Vendor
TH0001@properautocare.com's Avatar
FWIW, PO203S is LESS aggressive then SIP.
To find out how Menzerna polishes generally react with LC pads, these charts might help out. From this post on Truth In Detailing.
We created these charts as a guideline to help better understand the Menzerna polish line. Menzerna originally formulates their polishes to be used at the OEM level, which means that these polishes are used on an assembly line to remove paint defects at the factory on fresh paint. Often these polishes are applied with extremely high speed pneumatic Random Orbital Polishers. Many times the polishes are tweaked to meet specific factory requirements based on the exact paint system, assembly line speed, and geographical location/ environmental conditions..
In 2002 Proper Auto Care sought to bring Menzerna to the US enthusiast market. At this time Menzerna's United States distributor was focusing on the OEM market. Proper Auto Care struck a licensing agreement with Menzerna of Germany to import the polishes and expand the product line. All of Menzerna's OEM polishes where diligently tested. The best products for the end user market: Pos34a (Power Gloss),PO91e (Intensive Polish) and PO85u (Final Polish), and PO115c (Finishing Touch Glaze) where carefully chosen to launch the line. These products, still viable today, where the most consistent preforming Menzerna polishes at the time. Proper Auto Care replaced Final Polish with PO87mc Micropolish which was appropriately renamed Final Polish II. They continue to work on all paint systems including lacquer, enamel, high solid, water based, single stage, and nano technology paints.
No one in the United States has sold Menzerna polishes to the enthusiast and end-user market longer then Proper Auto Care. It is our belief that no one has invested as much time or has as much experience in fully understanding the Menzerna product line-up. Because these polishes where OEM designed for OEM market, they can exhibit some unique characteristics in their application when used in the dynamic environments that detailers and enthusiasts face. The tools that enthusiasts and detailers commonly use, including Random Orbital, Dual-Action, and Rotary Polishers are far different the the tools used at the OEM level.
With the large number of Menzerna polishes available today there is a fair amount of overlap in each polishes function tweaked to the requirements that polish was designed to meet. Given the factors given in the preceding paragraphs, along with the infinitive variable of the polishers technique, it is impossible to create concrete charts that will be 100% accurate 100% of the time. Rather we choose to create the most in depth charts that can be used as a general guildine to help our customers better understand the wide variety of quality Menzerna Polishes offered by Proper Auto Care.
Understanding the Charts:
Polishing Range- Menzerna Polishes utilize diminishing abrasives which have greater cutting power at the beginning of the polishing cycle. As these abrasives are worked over the paint they fracture, or reduce in size and sharpness, becoming finer. This 'break down' of the abrasives is what allows the polish to remove defects initially, and then as they become finer, polish the surface to a high gloss. Many factors effect the range the polish has, the most important two being the paint itself and the pad it is applied with. These charts are coded to specific Lake Country polishing pads, they show the initial cut of the polish and the types of defects that can be removed from typical paint systems, to the typical level the polish will finish at, or what types of defects will remain when the polish is fully exhausted and the abrasives have spent.
There are so many factors involved in paint polishing and so many factors that enthusiasts and detailers face that are different then the OEM level that these charts serve as a general, but thorough guideline.
Paint Condition/ Grit Level- The goal of polishing paint is to make it as microscopically smooth or level a possible. The smoother the paint is, the more gloss it has as light is evenly reflected away. Uneven, damaged, or scratched paint acts to refract or scatter light which causes a loss of potential gloss. On our scale, the higher the number, the more damaged or uneven the paint is, requiring more aggressive polishes and pads to smooth it out efficiently. Paint that is in very poor condition, scale 12-10, is very uneven and heavily damaged. The defects range in depth that would be seen if a piece of 1200-2000grit was rubbed into the surface.
Paint that is in a condition between 9-6 would have fairly moderate damage that would equal the depth caused by roughly 2200 to 3500 grit particles being rubbed against the paint's surface. Road grime that is heavy wiped into the surface or dirty brushes at a drive through car wash would typically cause this type of marring. These would constitute typical deep swirl marks.
Paint that is in condition between 5-2 would have moderate to light defects, such as wash induced marring or dust damage. The depths of defects would range from 4000 grit to a hypothetical 10,000 grit and should require very light polishing techniques to remove. Paint that is level two may appear perfect or near perfect and have excellent gloss. It is very possible to have paint in the range of 2 to 3 that will have no visible (macroscopic) defects.
Paint ranges below 2 deal with hypothetical grit numbers for comparison and for the most part microscopic defects that rob the slightest amount of gloss from the paint. The grit numbers range from 10,000 to 40,000 grit. Paint can never be truly perfect, at the microscopic level there slight differences in height. The grit numbers are solely to illustrate that even when paint looks perfect it can be refined finer and finer in order to achieve slight levels of gloss improvement. Wiping a fresh, plush, clean microfiber towel against clean paint will at some level impart some slight amount of scratching on the paint's surface at the microscopic level. To the naked eye we will see no loss of gloss, but science tells us that it does exist. We estimated this type of near impossible to detect super microscopic marring at 40,000 grit for reference.
Hard Paint Polishing Chart
Meduim Paint Polishing Chart
Soft Paint Polishing Chart
COMPOUND
POs34a Power Gloss Compound
Power Gloss is a nice cutting compound that is recommended for use with a rotary polisher. Power Gloss is very effective at removing sanding scratches, deep swirl marks, and other extensive damage.
Cut: High
Finish: Moderate
Dusting: Moderate
Filling Potential: Low
Ease of Use: High
Medium Cut Polishes
PO83q 'Super' Intensive Polish
'Super' Intensive Polish is an amazing polish which can remove moderate to severe defects and finish out to super high gloss with very little swirl. 'Super' Intensive Polish features a super thick lubricant which can cause problems on certain paints or in certain climates. The lubricant can be difficult to remove fully as well, leading to unintentional filling.
Cut: Moderate-High
Finish: Good
Dusting: Minimal
Filling Potential: Moderate
Ease of Use: Moderate
PO91e Intensive Polish
Intensive Polish is one of the original polishes introduced by Proper Auto Care in 2002. While no longer the class leader in cutting or finishing ability, Intensive Polish still has many desirable features. It will work well on all paint types, delivering consistent results with out any unwanted reactions. The dusting of the polish acts to keep spent paint from contaminating the pad, making Intensive Polish ideal for oxidized or heavily weathered paint, as well as single stage enamels and lacquers.
Cut: Moderate
Finish: Moderate-Good
Dusting: Moderate-High
Ease of Use: High
Final Cut Finishing Polishes
PO106ff/PO106fa
106ff was Menzerna's finishing polish answer to modern ceramic clear coats. This polish has enough cut to tackle light swirl marks and finish most paints to the highest level. The thicker lubricant system in 106ff can cause light filling and cause some issues on particularly soft paint systems. Menzerna tweaked the lubricant formula slightly to better hold the abrasives in the pad, reducing dusting, in 106fa. It should be noted that these polishes use the finest abrasive of any Menzerna polish.
Cut: Moderate-Light
Finish: Very Good
Dusting: Moderate(106ff) Light(106fa)
Filling Potential: Moderate-Low
Ease of Use: High
PO87mc Final Polish II
PO87mc Final Polish II is a great, easy to use polish that finishes exceptionally well on all paint systems and wipes off easily. Final Polish II breaks down quicker then the other Menzerna finishing polishes, making it an ideal choice when a time deadline is near.
Cut: Light
Finish: Very Good
Dusting: Low
Ease of Use: High
PO85rd Pristine Finish
Even though PO85rd was replaced by 106ff/fa in European automobile factories, detailers and enthusiast found this polish to be one of the best final step polishes in existence. It is commonly used as a 'jeweling' polish to enhance the gloss of already great looking paint and create ultra sharp reflections and incredible gloss on all paint systems.
Cut: Light
Finish: Very Good
Dusting: Low
Ease of Use: High
TH0001@properautocare.com is offline   Reply With Quote
Old 01-12-2010, 12:30 PM   #16
blackmachdown
CF Senior Member
blackmachdown's Avatar
Send a message via AIM to blackmachdown
wow those charts are excellent! thanks PAC!
blackmachdown is online now   Reply With Quote
Old 01-12-2010, 04:01 PM   #17
Former Vendor
Always solid information from ProperAutoCare!.............
Reload this Page Menzerna Power Gloss
Tags
203s, compound, cut, fast, finish, foam, gloss, menzerna, power, powerfinish, ppi, review, rotary, sip, speed, tips, tricks, white, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tried Menzerna Intensive Polish... =( KnightRider02 Car Care Discussion 21 05-25-2005 02:39 AM
Removing light scratches? Railfan Car Care Discussion 28 05-19-2005 11:12 PM
fine scratches-suggestions? Sacredgrooves Car Care Discussion 14 03-30-2005 11:36 PM
Car wash swirls David G Ford Car Care Discussion 14 03-21-2005 04:00 AM
New Product Tests (Wheel Cleaner and QD) Killrwheels Car Care Discussion 26 03-15-2005 04:57 PM
Need advice on swirl/scratch removal Z06ufgrad2002 Car Care Discussion 15 02-26-2005 03:27 PM
HELP!!! swirlmarks in my new paint job need-for-speed Car Care Discussion 28 02-20-2005 01:02 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
