White grunge on my tires?
I pulled the snow tires out to swap with the summer wheels today....yup...winter's coming. I found this "funky" white grunge on the tires. The picture is after three scrubs with Eagle One Wheel & Tire which as we all know.. cleans everything.
I found it rubbed off which you see at the 1:00-2:00 position. I remembered I had some Mr Clean white scrub pads which helped get a lot of it off.
Question is why did this grunge form. I'm thinking I might have used a can of spray-on foam cleaner-shine at some point last winter that wants to cling on the tire.
Anyone else run into this?
Received 4,543 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Probably a combination of the oils in the tire bleeding out and whatever salt/dirt that had accumulated on them before they were put away. I have had good luck cleaning with Westley's Bleach White and a soap impregnated Brillo pad and a stiff brush. Then hit it with Zaino Z16 or whatever you like.
