Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2009, 06:26 PM   #1
arkus
CF Senior Member
arkus's Avatar
Default whats the best product to remove polishes
I know alcohol will remove polishes , but is there an automotive one that is designed especially for that purpose ?
arkus is offline   Reply With Quote
Old 11-20-2009, 10:51 PM   #2
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
Menzerna Finishing Spray comes to mind ... sure Griots has one too.
Killrwheels@Autogeek is offline   Reply With Quote
Old 11-21-2009, 05:47 AM   #3
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
[Menzerna Finishing Spray comes to mind...] to remove polish?
Are you refering to Top Inspection or another Menz product?
TOGWT is offline   Reply With Quote
Old 11-21-2009, 11:50 AM   #4
0Detailed Image
CF Senior Member
Quote:
At first I use a microfiber towel to remove the excess product on the surface. They are paint safe and highly effective at collecting the remaining product.
Polishes can contain a very little bit of oil for workability which can stay behind even after a careful removal. You can remove that with a product like Menzerna Top Inspection Spray as mentioned above. The other option is to use a product like the Chemical Guys Vertua-Bond 408 which helps remove any residue left behind and leaves the surface very clean. It helps the sealant or wax applied next to bond with the paint for optimal durability.
Let me know if you have any other questions.
Greg @ DI
Detailed Image is offline   Reply With Quote
Old 11-21-2009, 12:23 PM   #5
petiebear
CF Senior Member
petiebear's Avatar
Is it okay to use half water and half alcohol ??
petiebear is offline   Reply With Quote
Old 11-21-2009, 12:54 PM   #6
steve8
CF Senior Member
steve8's Avatar
Quote:
If you guys are referring to after polish/before sealant/wax, then I use MF towels and then either a 50/50 water/alcohol or Z6 with MF.
I use ZPC as my final polish so I'm comfortable either way.
steve8 is offline   Reply With Quote
Old 11-23-2009, 02:07 PM   #7
arkus
CF Senior Member
arkus's Avatar
Top inspection and Ventura bond was what I was looking for . Thanks
Old 11-30-2009, 12:10 PM   #8
TH0001@properautocare.com
Supporting Vendor
TH0001@properautocare.com's Avatar
FWIW, I find alcohol to do a better job a removing some of the more stubborn polishing residue then Menzerna. I have never tried Ventrua bond.
Some polishes on some paints will just act funny. For example I usually get a weird reaction with Menzerna PO106a. The polish will tend to dry out quickly and may spit little worms of product out (if it is a CCS pad) or the rotary will bog down. It usually will take 2-3 wipe downs with heavy strength alcohol to reveal the surface. In cases similar to these, where the lubricant has become stuck on the surface Menzerna Top Inspection didn't help the process and worked similar to heavily diluted alcohol.
In most cases either a light dilution of alcohol or Top Inspection will work find, but keep something stronger around in case you need it.
TH0001@properautocare.com is offline   Reply With Quote
Reload this Page whats the best product to remove polishes
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
