Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-17-2009, 03:43 PM   #1
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Default Autogeek or anyone, consequences of not breaking down polish enough?
Lets take Menzerna Power Finish for example. If you're machine polishing and you don't break down the abrasives long enough, what happens? How can you tell when the polish is broken down to where it should be?
03 Z-oh-6 is offline   Reply With Quote
Old 11-17-2009, 03:54 PM   #2
arkus
CF Senior Member
arkus's Avatar
I have often wondered the same thing . Also can the polish be overworked?
Good post BTW
arkus is offline   Reply With Quote
Old 11-17-2009, 04:28 PM   #3
mikephillips@autogeek.net
Premium Supporting Vendor
mikephillips@autogeek.net's Avatar
If you're using a product that utilizes diminishing abrasives, and you don't work the product until the abrasives have completely broken down, then you risk leaving swirls by the yet not broken down abrasives.
That is if the abrasives still have a size to them and you're moving them over the surface with pressure either by hand or machine, then if they are doing their job, (abrading the surface), then they will likely be leaving swirls or scratches behind.
As to how to know when the diminishing abrasives have broken down?
Use the manufactures recommendations as your first point of reference and then after that experience and trial and error.
There are different types of diminishing abrasives as well as sizes and concentrations in a formula so there is no hard rule that applies to all products.
One mistake I've see people make over the years however is to skip reading the manufactures directions on the label and then using a product in a manner that's not in line with the directions.
For example, I've seen a lot of people try to use Meguiar's M01 Medium Cut Cleaner with a DA style polisher when right on the back label is says for use with a rotary buffer only and part of the reason for this is because it takes the power of a direct drive tool to effectively work the abrasives enough to break them down.
Lots of factors involved, playing with and testing a product on a black or dark colored finish and then inspecting with bright lights should help you see if you're getting good results or not.
In most cases you want to work a product long enough to break down the diminishing abrasives but not so long that you go to a complete dry buff. When you buff to a dry buff you have lost all lubricity and so the potential for friction increases.
mikephillips@autogeek.net is offline   Reply With Quote
Old 11-17-2009, 04:33 PM   #4
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Thank you MIKE!!! I was hoping you would chime in!!
How about 105 and 205? Are those easier to work with as a result of non diminishing abrasives?
Old 11-18-2009, 12:51 PM   #5
stig-zzz
CF Senior Member
stig-zzz's Avatar
meg's 105/205 not so much easier but FASTER your not spending as much time waiting for the polish to break down, the abrasives don't diminish in-turn your polishing passes are cutting at your selected concentration of cut. less time wasted waiting for the polish to break down and do it's job
With Menzerna polishes the break down point is when the polish starts to change to a hazy clear color at this point it's broken down.
A trick you can use to extend your polishing time is to spritz with some distilled water to add some lubricity back into the polish
You don't want to dry buff (induces swirls)and saves on using more polish then is needed.
I hope this helps
John Stig
stig-zzz is offline   Reply With Quote
Old 11-18-2009, 01:21 PM   #6
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
I hope this helps
John Stig
Awesome advice John! Thanks!
Old 11-18-2009, 01:24 PM   #7
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
At this point, has the polish done its job, or this is when it starts to do its job?
Old 11-18-2009, 02:30 PM   #8
stig-zzz
CF Senior Member
stig-zzz's Avatar
Quote:
At this point the abrasives (Menzerna)have almost completely broken down (finest cut) if there is still lube present i would make a few more passes to get the most out of your polish. just DON'T DRY BUFF
If you are on your final polishing steps i would highly recommend the spritz with distilled water the polish is at its finest and with the added lube from the h2o you will increase the life of the polish at its finest state. it's called burnishing the paint for that little extra bling
John Stig
Old 11-18-2009, 04:15 PM   #9
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Difference between Diminishing and Standard Abrasive Polishes
Diminishing Abrasives Technology
A non-linear abrasive requires kinetic (or dynamic) friction - the majority of polishes on the market use a form of diminishing (non- linear) abrasive, which you polish to a ‘haze’ (i.e. when a polish "flashes" from a liquid paste to a light semi-dry haze, much like a coating of Vaseline®) the diminishing polish has then broken down and is ready for removal.
Diminishing abrasives, as the name suggests; reduces t he size of the abrasives randomly due to surface friction, and therefore go from removing paint defects to polishing, and then burnishing the paint, which produces a shine.
If you don't break them down sufficiently, you are just grinding those abrasive particles into your paint, without polishing it, which can leave behind marring and other paint surface imperfections. Therefore it is important to know when a polish has broken down because if you take it too far you will re-introduce surface marring by dry-buffing.
During the polishing process, trace amounts of paint and / or oxidation is removed; this can cause the debris and the polish to “load-up the pad. This can cause a haze to the paint surface, a wipe-down or a paint cleaning product will eliminate this.
Pros - Menzerna diminishing abrasive polishes are formulated with a long lasting lubricant. The abrasives break down before the lubricating oils dry out, thereby giving polish a longer working time and producing less abrasive dust and avoiding dry buffing.
Cons - Menzerna lubrication oils can be really resistant to removal; it may take 2-3 IPA wipe-downs.
Non- Diminishing Abrasives Technology
A linear abrasive that require time and pressure - unlike diminishing abrasives, which require kinetic (or dynamic) friction to enable the abrasives to 'break-down to obtain the best possible finish (and avoid holograms) non-diminishing abrasives react very differently. It will be as abrasive as you want it to be, time and pressure applied (linear abrasive) being its working criteria. Block wet sanding (finishing paper and a sanding block) is the most effective tool for paint defect removal because of its linear process you abrade the paint surface flat until the defects are removed. Non- diminishing abrasives, a flat foam pad and a rigid backing plate are very similar in application.
The other similarity between using a non-diminishing abrasive polish and block wet-sanding with finishing paper; the cleaner the media, the more consistent the polishing will be. It the polishing media becomes ‘loaded-up, they lose their abrasive abilities. A linear abrasive eliminates the ‘abrasive cycle’ as you have a constant and consistent abrasive medium, the longer you work the abrasive the more surface defects are removed.
Linear abrasive polishes / compounds provides a constant cutting abrasive, as the abrasives remains uniform in size throughout the polishing process, so you need to check the surface often. They should be used with a semi-rigid backing plate and a cutting foam or wool pad until the defects are removed (1200 – 1500 RPM).
Do not allow the polish lubrication too completely dry (as this will also produce holograms) and ensure that pad surface is cleaned by removing paint / polish debris regularly This type of compound / polish process usually requires subsequent polishing step(s) to further refine the finish and to produce a shine
Pros - because of its linear process you abrade the paint surface flat until the defects are removed.
Cons - the lubricating oils dry out, thereby providing a shorter working time, producing more abrasive dust and the possibility of dry buffing, hazing and holograms
An extract from one of a series of 110 in-depth, unbiased “Detailing Technical Papers” © TOGWT ™ Ltd Copyright 2002-2009, all rights reserved.
TOGWT is offline   Reply With Quote
Old 11-18-2009, 04:31 PM   #10
arkus
CF Senior Member
arkus's Avatar
Will a good quality pad conditioner used correctly prevent dry buffing ?
Old 11-20-2009, 12:16 PM   #11
stig-zzz
CF Senior Member
stig-zzz's Avatar
Yes and no
I find with meg's 105/205 priming the pad works very well because its a non-diminishing polish and dry's out fairly quickly.You get the same cut from start to finish and has plenty of product in the pad from loading up the pad(priming)
With Menzerna diminishing polishes not so much because you are trying to get the product to break down,if you keep infusing new product from(priming the pad)your polishing process never allows it to break down,so you never are polishing at it's finest cut .
Different products =different processes
I hope this helps good luck
John Stig
Old 11-20-2009, 12:40 PM   #12
TOGWT
CF Senior Member
TOGWT's Avatar
Yes and no
John Stig
Great information John
Old 11-20-2009, 12:48 PM   #13
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Excellent info!
IMO, it seems Megs products would be easier to work with for a beginner considering you don't have to "know" when the polish has broken down. I like the idea of getting the same cut from start to finish.
Reload this Page Autogeek or anyone, consequences of not breaking down polish enough?
Tags
autogeek, avoid, black, breaking, breaks, car, consequences, down, dusting, machine, paint, polish, polishing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
