Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-16-2009, 10:51 PM   #1
jabez
CF Senior Member
jabez's Avatar
Send a message via ICQ to jabez Send a message via AIM to jabez
Default Concrete
How do you get dried concrete off the hood of your car? Found some on my truck's hood. Thank god it wasn't on the Vettes.
jabez is offline   Reply With Quote
Old 11-17-2009, 09:21 AM   #2
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Concrete Spots:
Calcified water spots on paint and glass, water and concrete spots are pretty much the same chemically; calcium carbonate, with the concrete being cross-linked with water
Removal
• Apply 1:1 ratio water with distilled White Vinegar solution, and using a spray bottle, spray that mixture on the spots and let them "soak." Then rinse with water and repeat as necessary.
• If the ambient temperature water/vinegar mix does not work, warm (100-120 degrees) 100% distilled White Vinegar, saturate a clean kitchen sponge with pure vinegar and hold the sponge over the concrete spots for a few minutes
• If the above do not remove them try equal parts distilled water, isopropyl alcohol and distilled white vinegar. The acid in the vinegar will help etch and dissolve the concrete.
• Rinse the area thoroughly with water after the vinegar and then reapply wax or sealant to that area.
a) To remove concrete that has set use a Decontamination / Neutralization system
a safe alkaline wash and neutralizing system the ABC wash apparently loosens the bond with the clear coat, after using the wash simply lift off any concrete with a plastic razor, for smaller specks use detailers clay, any subsequent etching will require an abrasive to level the paint surface, and then reapply wax or sealant to that area.
b) Back-Set by Romix is an acid alternative with no fumes or odours, molecularly breaks down the ionic bond in Portland cement, completely dissolving and releasing the hardened cement from any surface it is adhered to. Chemically speaking, Back-Set converts the positive ions in the hardened matrix into negative ions, which dissolves the cement into mud that can be rinsed away. Because it works chemically, rather than mechanically, Back-Set may be used to remove cured concrete, mortar, grout, and stucco from virtually any surface without harm. Always apply Back-Set to a dry surface area
An extract from “Automotive Detailing, Inside & Out”, a knowledge base for the perfectionist © TOGWT ™ Ltd Copyright 2002-2009, all rights reserved. This book enables direct access to five decades of detailing knowledge and experience
TOGWT is offline   Reply With Quote
Reload this Page Concrete
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
garage floor tiles - help needed! Adrian-S C5 General 132 08-04-2011 01:21 PM
Ahhhh!!!! Rubbed wheel against concrete curb cebars Car Care Discussion 10 08-12-2005 10:12 AM
who in this world invented concrete highways? okies93 C4 General Discussion 23 05-23-2005 04:02 AM
Super Car Tires on concrete roads sfore93392 C6 Corvette General Discussion 11 04-18-2005 10:43 AM
Hit a concrete block in the middle of the road yestersay!! David426 C5 Tech 37 03-22-2005 02:53 PM
Pics of my poor baby after tangling with the concrete wall Scott78 C3 Tech/Performance 17 11-13-2002 01:27 AM
Totally Disappointed... 273 Rear End Concrete Man C5 Tech 21 06-04-2002 03:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
