Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-16-2009, 12:12 PM   #1
mikeyrko
CF Member
mikeyrko's Avatar
Default Best shine car wax
So what car wax gives the best shine?
mikeyrko is offline   Reply With Quote
Old 07-16-2009, 12:27 PM   #2
bugn
CF Senior Member
I like Souveran Paste followed by Pinnacle Crystal Mist Detail Spray for quick touchup.
bugn is offline   Reply With Quote
Old 07-16-2009, 01:18 PM   #3
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
The best shine comes from polishing the paint surface so its level, a wax / sealant will enhance the shine
TOGWT is offline   Reply With Quote
Old 07-16-2009, 01:33 PM   #4
RaskyR1
CF Senior Member
RaskyR1's Avatar
Quote:
+1
prep is key!
Quote:
Only you can answer that....though I can already see what is going to happen in this thread.
RaskyR1 is offline   Reply With Quote
Old 07-16-2009, 02:42 PM   #5
XtremeVette
CF Xtreme Senior Member
Cruise-In 1, 3, 9. 10& 11 Veteran
Support Corvetteforum!
XtremeVette's Avatar
XtremeVette
Send a message via AIM to XtremeVette
well I will give you a pretty overall answer. As stated by others...
1. Prep work is very important. You must have a perfectly clean surface. So wash the car good.
2. Once all cleaned up, buff it really well with either a rotary or a PC (orbital buffing unit) or use a clay bar on it. You want a surface perfectly smooth and contaminant free.
3. Once your done with even these first 2 steps, your car should look pretty darn good! You now should move on to either your favorite polish, wax, or sealant. It really all depends on what you like, how much time you want to spend working on it, and how much you can afford. 3 very key components.
For me I like to layer my products. This is my personal list.
1. Wash Car
2. Buff car
3. Polish with DuraGloss (let sit overnight to cure/flash)
4. Apply Opti Sealant (let sit overnight to cure/flash)
5. Apply DodoJuice purple haze and/or DodoJuice Blue Velvet (I have a darker colored paint...Electron Blue.)
In between all of this I use a spritz sealant as both my touch up layer and a touch up quick detailer. They work great (many brands out there) and offer a notch up from just quick detailers. The benefit is you can even get it on glass and it wipes streak free away and you get the benefit of having the rain bead up and during like rain storms you won't even need your wipers!
I recommend if your really serious about getting the shine you really want to search around autogeek.net's website and read up or detailedimage's site. Both offer a wealth of knowledge about getting that perfect shine as well as offer products in every price range that are much better then the stuff you would just pick up at the local autoparts store!
Good luck and be sure to ask any questions no matter how dumb or trivial you think they are....its how you learn!
XtremeVette is offline   Reply With Quote
Old 07-16-2009, 02:47 PM   #6
0Detailed Image
CF Senior Member
The shine really comes from proper prep work from the washing, clay bar and polishing steps. The sealant or wax can only really enhance the way the surface already looks.
If money is no object - Dodo Juice Supernatural or the Chemical Guys E-Zyme Natura
More reasonable priced waxes - Chemical Guys 50/50 Limited Series Concourse Paste Wax or any of the Dodo Juice waxes
Best Value - Poorboy's World Natty's Blue or Natty's Red Paste Wax
Our Dodo Juice products are 20% off through July 20th as well! If you would like help with any part of this process I'd be happy to help. Let me know if you have any other questions.
Greg @ Detailed Image
Detailed Image is offline   Reply With Quote
Old 07-16-2009, 02:56 PM   #7
dvilin
CF Senior Member
dvilin's Avatar
After you do all the prep work as outlined by others I like Satin Gloss Wax, easy to use and great shine.
dvilin is offline   Reply With Quote
Old 07-16-2009, 03:00 PM   #8
mikeyrko
CF Member
mikeyrko's Avatar
Okay I'm not that good at this so what all is involved in prepping?
Old 07-16-2009, 03:13 PM   #9
blackmachdown
CF Senior Member
blackmachdown's Avatar
Send a message via AIM to blackmachdown
at the very basic
wash the car with car soap
and clay bar the entire car
that should make your paint feel smooth and remove all the wax
next step would be to machine polish which using a pc/flex/rotary and various pads and compounds you polish the paint until all the swirls are gone and keep moving to a finer and finer compound until the paint glistens like a jewel or a mirror
then you would apply your wax or sealant which if you did the above steps properly you wont notice a difference, hence the "the results are from the prep"
blackmachdown is offline   Reply With Quote
Old 07-16-2009, 03:50 PM   #10
trickflow
CF Senior Member
Wet Ice Over Fire is slick
trickflow is offline   Reply With Quote
Old 07-16-2009, 04:29 PM   #11
XtremeVette
XtremeVette
Quote:
Originally Posted by blackmachdown View Post
at the very basic
If you need further explanation I recommend you check out this, scroll to the bottom, everything you could possibly want to understand is fully talked about:
http://www.autogeek.net/detailingtips.html
Old 07-16-2009, 05:02 PM   #12
RaskyR1
CF Senior Member
RaskyR1's Avatar
Quote:
I actaully like the Wet-Ice alone. Seems like the nuba lessens the slick feel a little. I've only topped it on one car so I need to play around with it some more. Definitely my new favorite LSP though!
Old 07-16-2009, 05:16 PM   #13
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
washing, claying, polishing (or paint cleansing) ... and then the wax or sealant.
The problem in general is the best looking wax is subjective and often based upon many variables. There are certainly All-In-One products (Klasse AIO / Optimum Polyseal / Pinnacles XMT360) that work well as a one step. But in most cases you will need to get products that specialize in each step to give you the best of the best finish.
In general some of the best waxes are Pinnacle, P21S, DP MaxWax, Collonite and Dodo Waxes. Some of the best sealants (synthetic waxes) are Wolfgang, Megs NXT, Four Star, and Duragloss. There are however many great lines like Poorboys that could be considered too.
If you need some help, consider a call to us. Its toll-free and we have a tech area that can explain each process and we have a "detailing how-to" section in the toolbar on site too. Let us earn your business the correct way which is before, during, and after the sale.
www.autogeek.net
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is online now   Reply With Quote
Old 07-16-2009, 06:13 PM   #14
trickflow
CF Senior Member
Quote:
Yep, two applications of Wet Ice is smooooth. But ya gotta have the cure time between.
Old 07-17-2009, 12:51 AM   #15
blackmachdown
CF Senior Member
I didnt like the midnight sun wax at all i traded it for some CG5050 and like it much better
however the blackfire sealant i do like alot
Old 07-17-2009, 03:58 PM   #16
RaskyR1
CF Senior Member
RaskyR1's Avatar
I'm going to try some Dodo Supernatural over it and maybe some P21S 100% too. SN still looks the best to me out of all my nuba's.
Reload this Page Best shine car wax
Tags
84, auto, blackfire, car, corvettes, gloss, great, klasse, midnight, satin, sealant, shine, sun, vette, wax
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Vote for the best wax Cherry6speed C4 General Discussion 47 05-10-2004 11:47 AM
Best Car Wax Product Z Factor Car Care Discussion 31 04-23-2004 03:32 PM
Test RESULTS on CAR WAX..>> Gary@ronal C5 Z06 Discussion 18 06-18-2003 01:03 AM
WHAT IS THE 'BEST' POLISH, WAX, ECT. TO USE ON VETTE? daffyky Car Care Discussion 57 01-10-2003 11:35 PM
Has anyone ever use Zymol car wax? Road Racer C3 Tech/Performance 24 10-23-2002 07:19 PM
Best car wax at an auto parts store CorvetteGeo C4 General Discussion 31 10-02-2002 01:01 PM
Car Wax - Polish other than Zano due to time… C5VetteJoe Car Care Discussion 12 04-17-2002 05:57 PM
P21S Car Wax........??? RedSeeFive Car Care Discussion 18 10-26-2001 10:19 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
