Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-13-2009, 02:26 PM   #1
Gideon's_Test
CF Senior Member
Gideon's_Test's Avatar
Default Help! Water Spots on My Zainoed C5!
I went throughmy usual early summer detailing process with new products, starting with Meguiar's 105/205 with my PC7424. Got amazing results, and followed it up with a couple of layers of Z2/Z5 with Z6 in between..It looked good (I will mention that I had hoped for a better gloss, but it wasn't bad. If I had it to do over, I'd skip paying $100+ and use Klasse or equivalent).
In any case, we had a two week shut-down, and while I was off work, I kept the C5 in the driveway. A couple days ago, I washed it with Z7 and blow dried it and noticed what looks like water spots all over the paint...I tried a bit of Z6 and buffing which had no effect...Anyone know what will get this off? Hopefully, I do not have to entirely re-do my detailing!
Gideon's_Test is offline   Reply With Quote
Old 07-13-2009, 03:45 PM   #2
ZaneO
CF Senior Member
ZaneO's Avatar
Really depends on the water source and length of time. A healthy washing might do it, claybar, distilled white vinegar may do it, or it could require polishing.
__________________
Zane Oliver
ZaneO is offline   Reply With Quote
Old 07-13-2009, 03:50 PM   #3
Gideon's_Test
CF Senior Member
I'll try those suggestions in the order suggested. Perhaps using the chamois instead of blowing will help as well..
Old 07-13-2009, 05:38 PM   #4
RaskyR1
CF Senior Member
RaskyR1's Avatar
Were you drying in the sun?
I'd go with the above and try the claybar. If that doesn't remove them then they have ethed the clear a little and may require a cleaner polish to remove.
RaskyR1 is offline   Reply With Quote
Old 07-13-2009, 10:04 PM   #5
Gideon's_Test
CF Senior Member
I make it a point to wash it in the shade...I can't imagine that rainwater would leave spots (it did rain while it was out)...
In either case, will driving it around for now make it any harder to get the water spots out? I.e, will they "cook" in?
Old 07-14-2009, 09:26 AM   #6
hcvone
CF Senior Member
Support Corvetteforum!
If you get the quick 1-2 minute showers and then the sun comes out you can get water spots, and in some areas those short showers can carry a lot of acid in the rain. Got a call last week from a small used car lot to look at his cars, about a dozen cars has acid etching so bad the glass was etched, clay did nothing cars all had to be buffed out
__________________
Carl V.
Huntingdon Valley, PA.
www.hcvind.com
hcvone is offline   Reply With Quote
Old 07-14-2009, 10:25 AM   #7
Dave1
CF Senior Member
St. Jude Donor '09
Dave1's Avatar
Quote:
No, once the water spots have dried out the damage is done....
Try a vinegar and water mix to begin with. If that doesn't work, clay bar it and as Rasky pointed out earlier, follow that up with a paint cleaner polish.
Hopefully you won't have to break out the 105 again.....
Good luck......
Dave1 is online now   Reply With Quote
Old 07-14-2009, 06:33 PM   #8
Onyasix
CF Senior Member
Onyasix's Avatar
Gideon, as others, I would recommend the clay bar approach first. I would experiment on a small select to see what results you are getting from what ever method you try.
In your application of Z-5 and Z-2, it was not clear as to which you used first? Z-5 should be followed up with Z-2 for best results. You need only to apply Z-5 if you have very minor scratches/swirls or other blemishes (water spots) that you are trying to get rid of. To achieve optimum shine, you need to apply several layers of Z-2 (with ZFX additive and Z-6 between layers). I would recommend a minimum of three layers Z-2 followed by Z-8 spray for that final touch to achieve optimum shine.
Just remember that for Zaino polishes to achieve their high level of shine and depth is through layering. Each layer gives you a little more shine and depth.
Onyasix is offline   Reply With Quote
Old 07-15-2009, 09:52 AM   #9
Gideon's_Test
CF Senior Member
Thanks for the comment and tips, guys...I plan to try it this weekend.
Onyasix: I started with Z5 (everything with ZFX), then, Z6, Z2, then Z5...I will try it as you suggested...Looks like Z5, Z6, Z2, Z6 Z2, Z6, Z2...I don't have any Z8 or Z-CS...
Old 07-15-2009, 11:35 AM   #10
RaskyR1
CF Senior Member
RaskyR1's Avatar
I'd suggest doing a test panel by taping off a section to see if you even notice a difference after 2 coats. If you just do the whole car you really have no idea if it improved (you only see what you want to see). You likely won't see a difference and there is no reason to waste product.
just my $.02
Old 07-15-2009, 11:44 AM   #11
Gideon's_Test
CF Senior Member
RaskyR1,
That is reasonable...
Reload this Page Help! Water Spots on My Zainoed C5!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
