Best Weatherstrip treatment?
I'm sure this was covered before, but I can't find anything searching. I think I've heard silicone, but also that areospace 303 was better because less greasy?
Thanks.
Thanks.
Former Vendor
It too is pretty nice ... but Einszett is absolute fav to date.
From the 303 Aerospace website;
Rubber Seals on your Vehicles
Rubber Seals - Not `Rubber' Anymore
Maybe not a surprise, but no longer are a car's rubber seals made from `rubber'. To keep the inside of your car quiet and dry, car makers use a specialized synthetic material called EPDM, (ethylene propylene diene monomer).
Real rubber, or blends containing real rubber, just cannot endure the direct exposure to sunlight(ultraviolet light) and the harmful-to-rubber oxidizing gases in our atmosphere (see Tech Facts Vol. 1). To quote from the engineering specs, EPSOM is "Ideal for outdoor applications because of its excellent resistance to ultraviolet light, ozone, oxidants, and severe weather conditions".
EPDM is great stuff, but it has some downsides. It's tear resistance is only fair, so sticking & tearing is not uncommon. And just like real rubber, it has extremely poor resistance to solvents (petroleum distillates) and oils.
"You mean I don't have to `protect' my car's door & trunk seals?"
That's right, and treating your seals with a leading-brand "protectant" is almost always exactly the WRONG thing to do to your seals. Any chemical product that contains oils or petroleum distillates is incompatible with EPDM.
TIP: NEVER apply any rubber or vinyl treatment that has an oily or greasy nature or contains petroleum distillates. READ THE LABEL! If a product contains petroleum distillates, do not apply it to your rubber seals.
Though its powerful UV screening benefit is not needed in this application, 303 Aerospace Protectant is great for cleaning EPDM seals and to keep them clean. 303 Aerospace Protectant makes EPDM seals look like new and PREVENTS sticking and tearing. Because it is safe for EPDM and prevents sticking & tearing, manufacturers exclusively recommend 303 Aerospace Protectant for this application.
Former Vendor
I also really like the 303 Aerospace Protectant for any plastic, vinyl or rubber trim. It leaves a nice matte finish and valuable UV protection. It's a really versatile product that I tend to use all over a vehicle. If you have any other questions please let me know.
Greg @ Detailed Image
Aerospace 303 is my choice.
I like Krytox, it actually softens the rubber, its used for conditioning o-rings among other uses. I think it's a few steps above dielectric grease. You can find it at Leslies pool supply under the name Leslie's Pool and Spa Lube.
Former Vendor
I love the product and have found absolutely no harm after 3 years of use. I think the container makes is easy with no mess too. Its actually kinda fun and I allow my son to trace the weatherstripping with it.
