They sell a kit at Autogeek and it's cheap...Forever Black..I use it for little touchups, but have seen it done on whole cars with superior results..This is a dye which is PERMANENT and doesn't wash away..
Do not know about absorber, I have never used it, I use Guzzlers to dry my car. As for the trim best thing we have seen out there is Black Wow or if you want to dye it back to black use Forever Black
I would only add Poorboys Trim Restorer as a replacement for Black WoW as wanted. Forever Black is a more permanent dye solution and usually needs a couple coats for best look and even appearance then you can leave it alone for months as wanted.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
I bought a Meguiars microfiber drying cloth. Can I use DP microfiber cleaner to wash this? I only ask because it's not your typical looking microfiber.
you can ... yes ! Likely its not as soft as ours, but Megs makes nice towels. (smiles)
Out of curiosity, are you referring to cobra's guzzler microfiber(waffle weave) drying towels? I have them, but definitely prefer the chamois feel. The Megs microfiber drying cloth has a close feel of a chamois, but does not drag as much.
chamois have no nap, unlike a waffle weave and can introduce swirls rather quickly if any sand or contaminent blows onto paint between washing and drying. While it might move a little easier, it is a little riskier IMO.
spray the damp finish with a quick detailer, and then lightly allow WW MF towel to glide across finish. It might make it a little easier and also help prevent swirls. Might also add some gloss between wax sessions ...
