Black trim is turning white!
I know this is a Corvette Forumn....but....I have an 05 Ford Expedition that has the black plastic panels half way down the door. They are turning white. I have applied Zaino Clear Seal on them for the past 2 years but they have still turned white. I have sprayed Stoner brand Trim Shine on them and they look great, that is until the next washing. Then, they are whitish again.
Is there any product out there that will keep them black, even after washing? What bothers me the most is these panels go all around the car so about 1/3 of the total exterior is covered with them.
Help!
Help!
Try this: I tried it on my Mini Cooper black fender/skirt trim, it's great, last a long time and does not attract dust:
http://www.foreverblack.com/products.htm#bumper
Former Vendor
most products will only last a couple weeks to a month. Some of the best are 303, Black Wow, and Poorboys Trim Restorer. As offered above their are several dye products that will last considerably longer. The key is uniform coverage !
http://www.autogeek.net/excarcar.html
Autogeek:
I went to the link you posted and looked at all the products you offer.
Which product do you recommend? I want one that will last more than a few car washes.
Would it be possible for me to call you? I have several other issues I need resolved and would prefer to speak with you about them?
Thanks for your help!
Rob
Rob
Former Vendor
Rob, call our toll free number on Monday and ask for Dwayne, Meghan, or Matt and they will assist. I am offsite and can be reached thru email and PM when needed as a backup.
Scott
http://www.autogeek.net/forblacbumtr.html (Dye, long term)
http://www.autogeek.net/black-wow-trim-restorer.html (monthly application needed)
Scott
Autogeek:
Which product do you recommend? I want one that will last more than a few car washes. Keep in mind the car sits outside 24/7 and I am located in Phoenix...hot!
It sounds like a severe case of sun fading. I had the same problem when I lived in Florida. Unfortunately the vinyl needs re-colored or replaced. I chose to replace and to protect the new using 303. It minimized the fading and stayed pretty nice through each washing. I did apply it after each cleaning and was happy with the results until I sold the car.
I now offer a very similar vinyl product in www.MAGDANA.com called VS-40. High sun screen capability. I use it religeously on my Tundra dash/trim. It's also great on tires to slow the fading and rotting caused by long exposure to the sun. Check it out.
Joe Johnson
jj@magdana.com
Joe Johnson
jj@magdana.com
Former Vendor
http://www.autogeek.net/forblacbumtr.html (dye)
