Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-17-2008, 11:46 AM   #1
jason@autogeek
Platinum Supporting Vendor
Send a message via AIM to jason@autogeek
Default Menzerna Power Finish PO 203 now at Autogeek!
Get two-step results with Menzerna’s all-in-one swirl remover and polish!
Menzerna Power Finish PO 203 one polish designed to produce a fantastic gloss in less time than a two step polish process. Designed for the OEM market, Power Finish delivers a shine like Nano Polish with a cutting ability approaching Super Intensive Polish. Eliminate imperfections and rev up the gloss in just one step!
Menzerna Power Finish PO 203 is made for the OEM market as a quick way to polish out light flaws and amplify the paint’s gloss. It has the cutting ability just a step below Super Intensive. This will remove moderate to mild swirls, water spots, and light scratches. Then Menzerna Power Finish PO 203 does something amazing – it burnishes the paint to an ultra high gloss, like you’d expect from Nano Polish. For busy detailers, Menzerna Power Finish PO 203 saves time and money by doing the work of two products.
Menzerna Power Finish PO 203 at Autogeek
jason@autogeek is offline   Reply With Quote
Old 09-17-2008, 02:34 PM   #2
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Power Finish (PO203S) - will remove 2500 grit, cut 0.0- gloss 0.0, Slightly more abrasive then PO 106 but produces a burnished finish, (black or dark coloured paint surfaces use as part of a duel level foam pad / polish system PO 85 RD 3.01 Super Intensive Polish) 1500 RPM - primed LC Orange / Green (mid range, high density foam (60 PPI) medium abrasive cutting action) or a White primed (softer less dense foam (70 PPI) with a light abrasive cutting action) this is a a one-step scratch remover and polish
* cut between SIP and 106
See also article - http://detailingwiki.com/index.php5?...zerna_Polishes
TOGWT is offline   Reply With Quote
Old 09-17-2008, 06:44 PM   #3
Killrwheels@Autogeek
Killrwheels@Autogeek's Avatar
This is a nice offering for those not needing SIP but need a bit more bite than Nano polish. A great addition.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 09-17-2008, 11:41 PM   #4
gregs94
CF Senior Member
you say this is a step below SIP so where does that leave the IP and the final polish? outdated??
gregs94 is online now   Reply With Quote
Old 09-18-2008, 09:11 AM   #5
0Z06Joe@AutoBuffs
CF Senior Member
MD Events Coordinator
St. Jude Donor '08-'09-'10
Looks like I will be purchasing this to use on the daily driver....
Z06Joe@AutoBuffs is offline   Reply With Quote
Old 09-18-2008, 07:51 PM   #6
Quote:
I need to get some in hand to really play with it.
__________________
Reload this Page Menzerna Power Finish PO 203 now at Autogeek!
Tags
203, finish, menzerna, power, step
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
