Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-16-2008, 12:01 AM   #1
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Default Autogeek, I need help...
I bought the G110/Menzerna 5.5" kit specifically for my C6. However, my sister saw how good my car looked after the detail, she asked me if I could do hers. Being the nice brother I am, I said ok.
Anyhow, I want to buy proper pads for her 2004 Black Honda Pilot. I was thinking CCS 6.5" orange for the SIP, and CCS 6.5" white for the Nano, good choices? What speed for each polish should I start with for the Honda Pilot clearcoat?
The Meguiars backing plate sucks that came with the G110, will the lake county backing plate work with this unit?
Thanks!
03 Z-oh-6 is offline   Reply With Quote
Old 09-16-2008, 10:01 AM   #2
jason@autogeek
Platinum Supporting Vendor
Send a message via AIM to jason@autogeek
Thanks!
One thing to keep in mind, the SIP and Nano were designed for harder paints (Ceramiclear) and Honda is known for having a softer clear coat. Start with a slower speed that you usually do and test a small area out until you get the desired results, then do the entire vehicle. These products can be used on all paints, you will just need to make adjustments in the speed settings and technique to get the best results on softer paint.
The Lake Country backing plate will also fit on the G110, they have the same thread size.
jason@autogeek is offline   Reply With Quote
Old 09-16-2008, 10:09 AM   #3
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
What is a good combo(other than Menzerna) that wont break the bank for the Pilot, and what color pads would I use for each? I have some left over Adam's swirl remover and revive polish...
Old 09-16-2008, 10:27 AM   #4
Autogeek.net
Autogeek.net's Avatar
You can stick with those products, especially if the paint has any reasonable amount of swirling. I would use an orange or white pad for SIP, and a green pad with Nano.
ALWAYS use these products on speed 6 as they are designed for rotary use, and you need all the heat you can get to break down the abrasives!
Autogeek.net is offline   Reply With Quote
Old 09-16-2008, 10:43 AM   #5
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Out of curiousity, what are some other good products that are designed for DA polishers, but can still work on hard ceramic clearcoats as well as softer clearcoats? Kind of a universal polish is what I'm getting at. I like to have a variety of products on hand...
Old 09-16-2008, 10:54 AM   #6
Autogeek.net
Well, you won't find much out there better than Menzerna...what you have is indeed quite versatile and can be used for different applications simply by changing your pad selection. I've personally used SIP/Nano on softer Toyota paints with great results (and I will be again this weekend on a black Lexus), it all boils down to your pad choice.
If you still want to look into a great line of polishes that most people don't know about, 1Z/Einszett is top notch stuff.
Old 09-16-2008, 11:02 AM   #7
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
I'll stick with the Menzerna for now, but I will look into the 1Z because as I said, I like to have a variety of products on hand.
So, for the pilot, does it really matter if I go with 5.5" or 6.5" CCS pads? Orange SIP, Green Nano, and use the highest speed on the G110 as you suggested.
Old 09-16-2008, 11:48 AM   #8
Autogeek.net
Doesn't matter too much, but the 5.5"s will be a little more effective. Either way, you will get great results.
Old 09-16-2008, 06:23 PM   #9
Killrwheels@Autogeek
Killrwheels@Autogeek's Avatar
If you have the Menzerna twins, its the way to go. Try the SIP with white pad first and see if orange is really needed. Followup with finishing pad and nano. If you really want different polishes the Einszett Professional Line is nice, and always had good luck with Megs DACP but it sure is dusty.
Killrwheels@Autogeek is offline   Reply With Quote
Old 09-16-2008, 09:52 PM   #10
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Quote:
I don't know if I was doing something wrong, but the Menzerna twins sure dusted when I polished the C6.
Old 09-17-2008, 11:05 AM   #11
Autogeek.net
IMO any abrasive polish will give a slight amount of dust...Menzerna and Wolfgang dust VERY minimally, and if you use something like DACP which Scott mentioned, you will see what real dusting is.
Old 09-17-2008, 06:52 PM   #12
He aint kidding either
Reload this Page Autogeek, I need help...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Take a guess> Pledge? Zaino? Soverign? Wolfgang? or still wet???? YO-EL Car Care Discussion 31 09-06-2005 12:59 PM
Something is wrong - do I need help? Z0Sick6 C5 General 32 06-05-2005 07:53 AM
OMG, Zaino Z2 PRO has been released. This stuff rocks. agentf1 Car Care Discussion 37 12-18-2004 09:57 AM
Pinnacle cleaning kit blackz28turbo C5 Z06 Discussion 37 03-15-2004 04:33 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
