What Is So Special About ZFX?
Received 1,767 Likes
Re: What Is So Special About ZFX? (Corvettedon)
It make the Zaino polishes harder(more durable), last longer and shine deeper, as well as instant cure time allowing 3 application per day, back to back to back, and very fast if not instant drying time.
From what I can tell, it is a speeding agent. If you're not in a hurry to let the stuff cure, what does ZFX do?
Three years in the making, Zaino ZFX™ is finally here!
ZFX™, with Flash Cure™ (patent pending), is a revolutionary new polish
enhancement additive that's exclusive to the Zaino Show Car Polish system. There's
never been anything quite like ZFX™, and here's why:
All polish, sealant and wax protection systems must "cure" before they can
effectively protect your paint. Once cured, all paint protection systems begin to
deteriorate. The rate of deterioration depends on many factors, including the
chemicals used, bonding qualities, weather, washing, and use of the car.
A very few specialty paint protection systems can be layered to increase protection
and paint appearance. Layer-able systems must cure prior to application of
subsequent coats. Depending on the product, cure time may take a few hours or a
few days.
For lasting protection, most synthetic sealants are formulated to be hard. If not
properly designed, synthetic sealants may crack, yellow or distort the optics of the
paint surface.
ZFX™ is a Zaino Show Car Polish acceleration and appearance additive. It offers
near-instant cure time, reduced surface distortion, enhanced polish flexibility, and
improved bonding to both paint and additional layers of Show Car Polish. In
simple terms, ZFX™ vastly improves paint surface appearance and increases polish
durability.
ZFX™ is the product of more than 30 years experience painting show cars.
Professional painters add chemicals and compounds to their paint mix prior to
painting to improve paint flexibility, reduce paint imperfections, increase hardness,
and improve gloss. We applied this same line of thinking in the development of
ZFX™. The result is a stunning professional show car finish with less effort, no
waiting and longer-lasting results.
ZFX™ can be used with any of our Show Car Polish products, including Z-2, Z-3
and Z-5. Plus, ZFX™ makes using Z-1 PreLok unnecessary on cars that have been
clayed and thoroughly cleaned with Dawn dishwashing liquid.
When we say "acceleration," we mean it! Adding ZFX™ to any one of our Show
Car Polishes prior to use is like kicking an F-14 Tomcat into afterburner. The
competition just can't compete... we'll shoot them down every time. Perfect shine,
less time -- guaranteed!
A BEAUTIFUL SHOW CAR FINISH IN A DAY!
Zaino Show Car Polish is designed to be layered. With each layer you apply, your
car's paint looks better and feels smoother. Depth, gloss and clarity all increase
with each coat.
Like all other polymer based polish and protection systems, Zaino Show Car Polish
must cure before applying subsequent coats. The curing process allows the polymer
chains to cross-link, building strength and durability. If the polymer strands have
not cross-linked (cured), applying a fresh coat of polish will not achieve the
optimum layered result. Consequently, creating a show car finish can be a long
process of applying a layer, waiting, and applying another layer.
The Wait is Over!
Zaino Bros' ZFX™ Show Car Polish accelerator solves the wait problem. We
worked for several years to engineer a molecular reaction that causes the polymers
in Zaino Show Car Polish to set rapidly. Using ZFX™ with your choice of Z-2, Z-3
or Z-5 Show Car Polish, it is now possible to apply two or three coats of polish in a
single day to create beautiful show car special effects. The result is nothing less than
stunning.
ZFX™ saves you time and effort. It's no longer necessary to keep your car in the
garage for a whole weekend just so you can apply two or three coats of polish.
Using ZFX™, you'll apply multiple coats in just a few hours.
Prior to using ZFX™ Enabled Show Car Polish
Before applying ZFX™ enabled Show Car Polish, wash, dry and inspect your car’s
finish. It should be very smooth. If the paint has a rough, bumpy feel, you have
surface contamination which must be removed using our Z-18 ClayBar.
Prior to using Zaino Show Car Polish for the first time, we recommend using Dawn
dishwashing liquid to wash your car. Dawn will dissolve wax and other sealants,
and easily removes grease, tar and bug remains. Be sure to rinse your car very well
after using Dawn. After your first application of Zaino Show Car Polish, use Z-7
Show Car Wash for regular washing.
Mixing ZFX™ with Show Car Polish
Each ZFX™ kit comes with a 2ml vial of accelerator mix and several 2 ounce mixing
bottles. A single ZFX™ kit provides enough mix to accommodate 16 ounces of
Zaino Show Car Polish.
Pour one to two ounces of Show Car Polish into a 2 ounce mixing bottle. For each
ounce of polish, add 4 to 5 drops of ZFX™ (no more than 10 drops for two full
ounces), screw the cap back on, and shake vigorously for 60 to 90 seconds.
While you get your towels and applicators ready, allow the ZFX™ enabled Zaino
Show Car Polish to sit for five minutes so the ZFX™ can begin activating the polish.
Give the applicator bottle a final shake for 10 seconds before using.
Applying ZFX™ Enabled Show Car Polish
Follow these easy steps:
Apply Zaino Show Car Polish enabled with ZFX™ with a 100%, made in the USA,
cotton applicator. Use the polish sparingly. A small amount goes a long way, and
you will be applying multiple coats.
Squirt a dime size dab of polish on your applicator and rub it into your paint using
circular hand motions. Then, go over the same area using a straight back and forth
motion on top panels and an up and down motion on side panels. Allow the polish
to haze over (20 minutes is sufficient).
Buff off the Show Car Polish residue with a high quality, 100%, made in the USA,
cotton detailing towel.
After buffing, spray the car with a light mist of Z-6 Ultra Clean™ detailing spray.
Z-6 will help buff away any remaining residue and enhances the brightness of the
finish. Using Z-6, the next coat of Zaino Show Car Polish will apply even easier.
You're now ready to apply your next coat of Zaino Show Car Polish enabled with
ZFX™. There's no need to wait. Simply follow steps 1-4 above one more time. Use
a fresh cotton buffing towel to remove each coat of ZFX™ enabled Show Car
Polish.
Note: Apply no more than three coats of Zaino Show Car Polish enabled with
ZFX™ in a 24 hour period. For optimum results, use your ZFX™ enabled polish
within 6 hours of mixing. Use a fresh cotton buffing towel for removal of each coat.
Note: When you are finished polishing, wash the mixing bottle inside and out with a
heavy concentration of liquid dishwashing detergent and thoroughly rinse. The
ZFX™ mixing bottles cannot be reused if the polish remains in the bottle for more
than 12 hours. After 12 hours, it is not possible to completely clean the mixing
bottle. Throw the mixing bottle and any unused polish contents away after 12 hours.
Re: What Is So Special About ZFX? (KLO)
Okay, I'm naturally skeptic so I want to know if anyone has seen the benefits as far as "shine" goes. I don't need to do three coats in one day (unless it will be brighter than three coats done in three weeks). My car is going to be sitting most of the winter, so Zaino'g is going to be my way to "bond" to the car anyway. :D To me, it seems like this is a way to throw away some money if you don't use what you mix. (And there is no way you can precisely know how much to mix--which guarantees waist and profit for Zaino.)
Don't get me wrong, I am thrilled with Zaino. However, I do know that they are in business to make money--and rightfully so. I just don't want to throw away mine if I'm not going to get a better shine.
Again, has anyone "seen" a notable difference? My car is silver, so I don't think I see much more shine with Zaino. However, I do like the fact that dirt doesn't seem to stick. For me, my red IROC (w/Meguires) has a better shine. But, it is red and that makes a difference. Plus the car is in a bag so durability isn't an issue.
I will continue using Zaino on the Vette. But, I need convincing before I start mixing and tossing away unused (expensive) polish--even if it isn't a polish. :flag
No one at Zaino bros. is forcing you to use the ZFX. Some Zaino users will never ever use ZFX, ZFX is a companion product, not an essential one. Sal is still going to make the Z-1 as it has benefits on older paint surfaces. As long as you have Zaino now and you are happy with it, stay with what you have. ZFX is just for those that never liked the Z-1 step and for the guys who wanted to do multiple coats all in one day. Stay with the system you are using now. The other extra benfits Sal discoverd with ZFX besides the no Z-1 thing and multiple coats all in one day where just gravy.
Re: What Is So Special About ZFX? (JD 90 383)
KLO, I appreciate your input. I know nobody is forcing me to use ZFX. And, like I said before, I am pleased w/Zaino. In fact, I was reluctant to try Zaino because I am careful about following the crowd for the crowd's sake. But, as said, Zaino is good stuff. I am trying to see if ZFX is worth the investment in my situation. Since a greater shine is my main objective, I think you are right and I'll stay with my current method. Thanks again.
I know, I know Zaino does not shine on silver.
Just view the first 8 pics of the link below:
http://www.picturetrail.com/gmblack3/426788
I think Zaino is the best but just to ask how much more can a car shine. I do it to protect the paint surface and just to keep it looking good. If you park 2 vettes together and one had 3 or 4 coats of Zaino and the other one had 20 - 25 coats would you see a difference? Just wanted to know.
any chance of them making an all-in-one product?
Right now you need something like 4 different products to do the job correctly, kind of gets confusing.
Re: What Is So Special About ZFX? (MJM)
The ZFX replaces the Z-1 for a catalyst for the Zaino polishes, ZFX can only be mixed for so long as it has a pot life, after that the Zaino goes back to a normal state, same way with the Z-1 activator, it can not come in the same bottle as Z-2,3, and 5
Zaino really does not have more or less steps than other car care companies, all have a pre cleaner in their line up (Z-1) all have a detailer spray in their line up (Z-6) all have a car wash in their line up (Z-7) and most all major compaines (i.e. Meguiars and Mothers) now have clay bars in their line up (Z-18)
