Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-28-2008, 08:35 PM   #1
JoshVette
CF Senior Member
JoshVette's Avatar
Default Full Write Up, 1966 Pontiac Lemans Show Car, Fully Sanded and Polished
I rarely ever post up and brag about my own work, but I thought this was worth reading. check it out.
Lots of information for the DIY's as well as the pro's.
This is a very lengthy, thorough and detailed write up of the exact process, steps and techniques I performed on a 66 Pontiac Lemans that was fully color sanded and polished out to perfection.
If anyone is curious what it takes to paint and perfect a car, this is what you want to read.
Please understand why I posted a link and did not rewrite the entire documentation as it took me over 5 hours just to do the write up.
Thanks and enjoy,
Josh
http://www.autopia.org/forum/pro-det...polishing.html
JoshVette is offline   Reply With Quote
Old 07-28-2008, 08:48 PM   #2
GS4-LT1
CF Senior Member
GS4-LT1's Avatar
Beautiful work Josh!!! Man that is a lot of sheet metal, and Black to boot!!! I like Megs 105, the initial cut is fantastic, I just wish it had a longer work time, if it did I think it would finish out better.
GS4-LT1 is offline   Reply With Quote
Old 07-28-2008, 09:07 PM   #3
Dave1
CF Senior Member
St. Jude Donor '09
Dave1's Avatar
Stunning work bro......
A first class job done by a real pro........
Dave1 is online now   Reply With Quote
Old 07-28-2008, 09:07 PM   #4
JoshVette
CF Senior Member
JoshVette's Avatar
Quote:
Thanks, you are right about the M105, it takes a little getting used to, but I find if you mix it with something like Menz SIP or IP or another polish that is loaded with lubes that it should spread so much longer.
And I find the trick to it is putting it on thick, then once you've worked it in, turn it down and jewel it a whole lot.
I got it to give me a nearly perfect, ready for wax finish. But I was using it after Menz PG so the PG left behind some valuable lubes which was perfect for the M105 to spread around with.
Josh
Old 07-28-2008, 09:09 PM   #5
JoshVette
CF Senior Member
JoshVette's Avatar
Thanks, Dave.
I thought it would be a good read for some people so I took extra time in the documentation as well as the write up.
No better tester for our products than black paint that has been fully wet sanded.
Josh
Old 07-28-2008, 09:23 PM   #6
TedG
CF Senior Member
TedG's Avatar
Location: Sparks (Reno is so close to hell you can see Sparks) NV
Wow!! A very informative posting. Beautiful job with the explanation as well as the work itself. I have buffed out some paint jobs before, but mostly just using what the guy at the counter at the paint store says is best. My results were at best marginal. I learned a lot.
TedG is offline   Reply With Quote
Old 07-28-2008, 09:49 PM   #7
JoshVette
CF Senior Member
JoshVette's Avatar
Quote:
You are very welcome. Glad I could help on some level.
Josh
Old 07-28-2008, 10:03 PM   #8
TedG
CF Senior Member
TedG's Avatar
Quote:
Josh
You did, thanks again. When I was younger, I worked weekends for my girlfriend's dad who owned a detail shop, he mostly did new cars from dealerships. But I learned how to use a buffer without burning through paint. But mostly it was to apply some gimmicky protection coating.
Old 07-28-2008, 11:06 PM   #9
Dave1
CF Senior Member
St. Jude Donor '09
Dave1's Avatar
The work time is very short, no doubt about it......
After trying the three small dot process some other guys use, I couldn't even do a one foot window without it drying up.....
If I need 105 now, I use a white rounded edge LC pad that's very moist with FK425. I spritz the paint surface to add a little longer working time.
The milder pad selection doesn't seem to hinder the strength of 105. It's some serious stuff and it finishes down crazy nice considering how potent is is......
Old 07-28-2008, 11:41 PM   #10
GS4-LT1
CF Senior Member
GS4-LT1's Avatar
Thanks for the tips with the 105 guys! I have a color sanding project coming up, so I will give them a try. FK425 is a product I have been wanting to try, everyone seems to love it, but I just bought 3 gallons of Megs Final Detail so I am set for awhile. Again awesome job on the car and the posting Josh...Thank You!!!
Old 07-29-2008, 12:12 AM   #11
roushraven
Coolest Guy Evar!
Support Corvetteforum!
roushraven's Avatar
Excellent work Josh. Everytime I think I'm getting somewhere I see the work you Pro's do and I get humbled.
-RR
__________________
Go: LPE C5R 427, LS3 heads, QMS 550 cam, Halltech CAI, LS3 TB, Ported LS3 intake, AR headers, RPM Level V, DTE Brace, PFADT suspension, LS7 clutch, TICK Master, WILWOOD SL6/SL4R, DRM brake ducts, MGW shifter
Show: CARAVAGGIO seats, BK camera mount, SS bezels, DRM hood, ACI chin spoiler/side skirts, RKSport CF brake ducts, O.Z. Superleggera III 18x10/19x13, INVO (275/35F, 325/30R), SCP LED tail lamps, Screwed up paint by AUTOBUFFS
RIP WRATH 11-Talon II Crew.
roushraven is offline   Reply With Quote
Old 07-29-2008, 01:01 AM   #12
JoshVette
CF Senior Member
JoshVette's Avatar
Yup, sounds like you got it. I like to put it on super thick though and still spritz it especially when using it via rotary.
Depending on the paint it will leave some holograms behind if using it with a wool pad but if a white pad on hard paint it's great and if on softer paint with a white pad it will haze a little I find. It's typically a good rule of thumb to finish down any compound when using a rotary to ensure holograms are not left behind.......as you know.
Josh
Old 07-29-2008, 01:01 AM   #13
JoshVette
CF Senior Member
JoshVette's Avatar
You're welcome.
Old 07-29-2008, 01:03 AM   #14
JoshVette
CF Senior Member
JoshVette's Avatar
Quote:
-RR
Thanks, I love what I do. It's nice to see results and I'm still learning everytime I see another pro do something that I haven't thought of yet or whatever.....
Josh
Old 07-29-2008, 08:32 AM   #15
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
EVIL_C5's Avatar
looks awesome! did you find it hard to remove the sanding marks that were not following a uniform direction? ie, lookes like the sanding marks went out in angular directions while the sander stood in the same spot if that makes sense.
when I did my car, I made the mistake once of going an oposite direction as I started and it was harder to remove the sanding marks.
EVIL_C5 is offline   Reply With Quote
Old 07-29-2008, 11:22 AM   #16
Autogeek.net
Platinum Supporting Vendor
Autogeek.net's Avatar
Very impressive!
Autogeek.net is offline   Reply With Quote
Old 07-29-2008, 11:32 AM   #17
steve8
CF Senior Member
steve8's Avatar
Even after all I have seen here by the several people who really know what they are doing, I am still surprised to see the levels of correction possible.
Great work.
steve8 is offline   Reply With Quote
Old 07-29-2008, 12:12 PM   #18
JoshVette
CF Senior Member
JoshVette's Avatar
Well, the painted did a lot of the sanding but he also had a couple helped who sanding a few panels so......
The worst areas were the trunk and passenger side rear panel, could be cause I did the testing on them though.... not sure exactly but they were a little more difficult to clean up.
Thanks, Josh
Old 07-29-2008, 12:16 PM   #19
JoshVette
CF Senior Member
JoshVette's Avatar
Quote:
Originally Posted by Autogeek.net View Post
Very impressive!
Thanks Autogeek. I had purchased those 6 purple foamed wool pads, 6 white pads, a gal of M105 and a gal of SIP from you guys just for this car...
Quote:
Great work.
Thanks, it was all finished down with 2500 grit uniform paper so it shouldn't have been so difficult to make perfect, it only gave me a little trouble in certain areas.
Josh
Old 08-02-2008, 07:44 PM   #20
ILLUSHN
CF Senior Member
ILLUSHN's Avatar
You did a great job bringing that paint job to life!
I love these threads that go into detail like this one did. I may never attempt one like that myself, but it sure gives you a greater appreciation for some of the paint jobs that you see at car shows.
Nice work!
Jeff
ILLUSHN is offline   Reply With Quote
Reload this Page Full Write Up, 1966 Pontiac Lemans Show Car, Fully Sanded and Polished
Tags
1966, 66, color, correct, engine, lemans, pontiac, show, worth
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
