Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-26-2007, 07:46 PM   #1
openhelix
CF Senior Member
openhelix's Avatar
Default what polish to use for swirlmarks?
My PC arrived from autogeek today but I realized I didn't order any polishes to go with it! Doh! I have some obvious (in the sun) swirlmarks on my VY C6. What polishes or combination of polishes are best suited for this? I have blue/white/black smart pads and AG orange pads. I plan to go over with Zaino (AIO/Z5/Z2/Z8) when I'm done.
Anything I might get locally (San Jose, CA) as I was hoping to do it this weekend with some time off.
Thanks!!
openhelix is offline   Reply With Quote
Old 12-26-2007, 09:02 PM   #2
0JPM@AutoBuffs
Former Vendor
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Location: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
Edited...Misread the Post...
The product used will depend on how bad the swirl marks are.
I would recomend trying Zaino Fusion / swirl mark remover.
I had good results with a black and Yellow CS Lake Country foam pad.
But again the pad will depend on how bad the swirl marks are.
Good luck.
JPM@AutoBuffs is offline   Reply With Quote
Old 12-26-2007, 09:40 PM   #3
openhelix
CF Senior Member
openhelix's Avatar
Hmm, polishes by their nature are abrasive. Are you maybe confusing polishes and sealants? Zaino PC Fusion is a polish.
Old 12-27-2007, 12:47 AM   #4
IAIA
CF Senior Member
IAIA's Avatar
Quote:
Zaino PC Fusion is in fact a polish. The Z2/Z5 combo are sealants. Polishes vary from mild to rough abrasives. If you're really in a time crunch, you can get some stuff to play with at a local auto supply store. See the chart at this link to identify various levels of abrasiveness: http://thedetailinghandbook.com/Polish_Chart.aspx
For expert polishing, I follow the guidance of the experts in here....the products that come up a lot are Menzerna's Super Intensive Polish, or just their Intensive Polish, followed by Final Finishing Polish II. An excellent polish that seems to combine the two and finishes up very well is Menzerna Nano Polish, but I've never used it. I personally use SIP for tougher swirls/marks, and either FFPII or Zaino ZPC, depending on my mood and how much product I have left.
I recommend you see if the fine folks at AutoGeek can ship you some before you need it this weekend...they can rush you out some for sure (ZPC must come from the Zaino folks)....otherwise, an Autozone would carry Meguilar's #9 (which is on that chart as a milder #3 cut) or #2 (which is a bit more aggressive at a #5 cut). Not the best products, in my opinion....However, a very good tide-me-over if the internet doesn't work for you is if you have a Napa Autoparts store near you....they would carry 3M's equivalent....the milder 39009 and the slightly more aggressive 39002.
Happy buffing! post some pics!
ps....I wouldn't use a black CS Lake Country foam pad....too soft. Most in here recommend the orange Lake County foam pad....maybe the white foam pad to finish, but even orange with a fine finishing polish works well.
IAIA is offline   Reply With Quote
Old 12-27-2007, 02:48 AM   #5
Junkman2008
CF Senior Member
Junkman2008's Avatar
Depending on how bad the swirl marks are, you may have to start with something that really cuts using a cutting pad. But what I would suggest first is going with some Zaino PCFusion on a orange pad that you get from AutoGeek. The secret to removing swirl marks is as much in the technique as it is in the products you use. Most products will do as advertised, but in the right hands a product can look like the cure to cancer. REMEMBER: Never use 2 different products on the same pad. Thus, buy all the pads you need.
The secret with removing swirls is to not overwork the product. Once the product breaks down to a certain point, you need to stop, wipe it off and inspect the area. This breakdown point comes relatively fast when using a buffer or PC. So it will take you a little practice to figure out when that points is reached (it varies with different products), or you'll just be putting swirl marks back on the car.
I also suggest that you order the How to Use the PC DVD (from AutoGeek). It gives some excellent tips on using that device for the novice user. I learned a ton from that DVD and after a month or two of using the thing, I'm becoming quite good at it, IMHO!
__________________
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Old 12-27-2007, 07:26 AM   #6
TH0001@properautocare.com
Supporting Vendor
TH0001@properautocare.com's Avatar
Quote:
Originally Posted by J.P.M. View Post
Polish will not remove swirl marks.
I had good results with a black CS Lake Country foam pad.
Good luck.
? A polish will remove swirl marks, a sealant will not... Very confused as to your post...
TH0001@properautocare.com is offline   Reply With Quote
Old 12-27-2007, 08:49 AM   #7
TR6speed
CF Senior Member
St. Jude Donor '11
TR6speed's Avatar
As an Adams user, I would recommend their Swirl and Haze Remover. Used it before you polish. Also depending on how bad the swirl marks are, you may need to use a more aggressive pad on you buffer. I have both the green and orange pad combo as well as the white and gray that Adams sells. I also suggest that you clay bar the car before you touch it with the buffer, that is if it has not been done in a while. Used the old plastic bag trick to see if claying is needed.
TR6speed is offline   Reply With Quote
Old 12-27-2007, 09:46 AM   #8
steve8
CF Senior Member
steve8's Avatar
I had great luck with MIP/orange pad, followed by ZPC/orange pad, and then on to Z5P and Z2P.
I have yet to use the ZAIO but have heard good things about it.
Don't rush to the sealants. If you are not happy with the finish then you are wasting your time and money.
steve8 is offline   Reply With Quote
Old 12-27-2007, 09:59 AM   #9
FloydSummerOf68
CF Senior Member
FloydSummerOf68's Avatar
Send a message via AIM to FloydSummerOf68
Meguiars makes a couple polishes that can pick up locally (I think it's called colorX)
Mothers also makes a polish now designed for an orbital buffer (their power polish)
Both of those can be picked up local and I'd try them out with an orange pad first...I wouldnt start with yellow.
FloydSummerOf68 is offline   Reply With Quote
Old 12-27-2007, 01:14 PM   #10
duckvett
CF Senior Member
duckvett's Avatar
Quote:
Regarding the Meguiar's product line, I have never used ColorX, but I don't think it is a product you would want to use on your Corvette. If you choose to use Meguiar's I would suggest starting with #9 Swirl Remover (the least aggressive abrasive), moving up to #80 if necessary. #83 Dual Action Cleaner/Polish is on the more aggessive side. A good rule of thumb is start with the least aggressive first and move up if necessary. Then come back to the least aggressive to further smooth and polish the finish.
duckvett is offline   Reply With Quote
Old 12-27-2007, 02:23 PM   #11
FloydSummerOf68
CF Senior Member
I didnt think that colorX was considered that abrasive (granted I dont know...I just didnt think it was).
Reload this Page what polish to use for swirlmarks?
Tags
aggresive, fusion, iaia12, intensive, menzerna, pc, polish, super, whats, zaino
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
HELP!!! swirlmarks in my new paint job need-for-speed Car Care Discussion 28 02-20-2005 01:02 PM
NXT vs. Zaino Z-Dreaming Car Care Discussion 57 07-02-2004 01:15 AM
Highspeed buff and polish FSTRNU C4 General Discussion 19 12-16-2002 02:56 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
