Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-26-2007, 04:25 PM   #1
papafrancisco
CF Senior Member
papafrancisco's Avatar
Default Bleche Wite On Wheels Clear Coat
I had surf the treads that were Bleche Wite related and found some enough encouragement that, I a layman to detailing by all means of the word, felt comfortable enough to try. What I read was mainly don't spray the wheel directly with the spray. I didn't. It dripped on the wheel. So I felt within a minute it wouldn't hurt. Boy was I wrong. I have some drip streaks across my wheels now. Has anyone had any luck in removing these streaks or do I fear the worse ie they're etched? I'm sending out an SOS...
papafrancisco is offline   Reply With Quote
Old 12-26-2007, 06:06 PM   #2
papafrancisco
CF Senior Member
These are clear coated wheels.
Old 12-26-2007, 06:25 PM   #3
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
this is where people fail to read the entire senario and post misinformation that can harm someone permanently:
1. Bleche White --- the spray that makes white walls white should never be used on painted surfaces, even the bottle warns of it. They do make a wheel cleaner (grey bottle) but much to harsh in my opinion for clearcoated wheels on a normal basis.
2. Metal Polish --- a metal polish should NEVER be used on a clearcoated wheel. Metal polishes are designed for metal wheels exposed the the elements. Wheels sealed via paint or cc are to be treated just as paint with a paint cleaner or paint polish as needed.
these streaks are likely etched into paint or scared clearcoat, but try a paint polish quickly and see if you can reduce their appearance.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 12-26-2007, 06:29 PM   #4
papafrancisco
CF Senior Member
Thanks Killr for the reponse
Old 12-26-2007, 11:25 PM   #5
PSU 98
CF Senior Member
PSU 98's Avatar
My apologies. I posted from my experience with aluminum rims. Misinformation deleted.
__________________
2003 Chevrolet Corvette
2002 Chevrolet Camaro Z28
1987 Buick Grand National
PSU 98 is offline   Reply With Quote
Old 12-26-2007, 11:58 PM   #6
mrosa65
CF Senior Member
Support Corvetteforum!
mrosa65's Avatar
It also does a number on zinc plated rotors.
mrosa65 is offline   Reply With Quote
Old 12-27-2007, 12:47 AM   #7
C4boy
CF Senior Member
C4boy's Avatar
Ditto what Killer said. The only way you can fix the clear coat streaks in the wheels is to try polishing them out with a good polish or wet sanding. Good meaning - a light abrasive polish w/No fillers.
How do I know? I used too heavy a degreaser on mine once and ended up refinishing the wheels.
C4boy is offline   Reply With Quote
Old 12-27-2007, 03:01 PM   #8
papafrancisco
CF Senior Member
I was lucky this time! I used a QD and the wheels shine as ever without any streaks. I must ask how do you use Bleche Wite without getting it on your wheels? You have to apply enough to clean the tire which at that point it begins to run/drip. I plan on using Simple Green next time to clean the tires.
Old 12-27-2007, 07:23 PM   #9
Quote:
I guess I might try a Wheel Shield in a pinch, but only as needed. I highly suggest a wheel cleaner like P21S or soap/water as needed versus store bought wheel cleaners (often contains lye or acid) and APC's.
__________________
Old 12-27-2007, 10:18 PM   #10
C4boy
CF Senior Member
C4boy's Avatar
Sounds like you lucked out. If you want to make sure the QD didn't just cover up the streaks, wipe the wheel down with some alcohol.
I don't use Westley's for the above reason. It's almost impossible to keep it off the wheels. I haven't had a problem with Simple Green or Eagle One AP wheel cleaner on clear coated wheels. Eagle One works pretty good at cleaning tires & brake dust, and no streaking.
Reload this Page Bleche Wite On Wheels Clear Coat
Tags
apply, bleche, blechewite, buy, clear, coat, coated, covered, pictures, polish, removing, rims, streaks, westleys, wheel, wheels, white, wite
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
