Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-25-2007, 04:52 PM   #1
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Default Another REJEX question :)
Will it remove light surface scratches and swirls?
03 Z-oh-6 is offline   Reply With Quote
Old 12-25-2007, 05:48 PM   #2
nmk
CF Senior Member
nmk's Avatar
No I don't think so, it's just a sealant. I used it on my vette last year and did really like it.
nmk is offline   Reply With Quote
Old 12-25-2007, 05:56 PM   #3
IAIA
CF Senior Member
IAIA's Avatar
No. Rejex is a sealant...a coating, like you would use wax but longer lasting and slicker than wax. You need an abrasive in the form of what is called a polish or swirl remover (very, very light abrasive) to remove light scratches and swirl marks. And on the Corvette clear coat, you need to either apply it by hand by moving your hand in circles at a speed of about 4-6,000 small circles per minute, or use a buffer at that speed.
IAIA is offline   Reply With Quote
Old 12-25-2007, 10:19 PM   #4
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Quote:
I have some Adams haze and swirl remover, should I apply that first, then adams polish, then Rejex?
Old 12-26-2007, 01:55 AM   #5
sabooher
CF Senior Member
Rejex is an LSP so you'll want to clean & polish the paint prior to applying. I tend to stay away from polishes that contain fillers.
I use Zaino PC Fusion (Z-PC) with my Porter Cable to polish and remove swirls after claying the surface (if it needs it), then apply Rejex and let it cure for 12 hours.
sabooher is offline   Reply With Quote
Old 12-26-2007, 02:55 AM   #6
IAIA
CF Senior Member
IAIA's Avatar
Whatever you use to remove the swirls...Adams, Zaino, Menzerna....be sure to wash the car afterwards to remove all traces of polish. You could even use 50/50 isopropyl to remove all remnants of the polish. The idea is to have as clean a surface as possible for bonding with the sealant, whether it be Rejex, Zaino, or your favorite non-sealant or partial-sealant wax.
Old 12-26-2007, 09:58 AM   #7
mrosa65
CF Senior Member
Support Corvetteforum!
mrosa65's Avatar
Quote:
rejex won't remove scratches or swirls and won't hide them. You'll have to use another product for that. Since you have Adam's products they will work. Be sure to clean the paint well after using the Adam's products so the rejex will bond properly since it's a polymer sealant. Try using a 50/50 (Isopropyl/water) mix in a spray bottle before using rejex. This will remove any residue left by the other products and allow the rejex to bond. If you want, then you can add a wax over the top of the rejex.
mrosa65 is offline   Reply With Quote
Old 12-26-2007, 10:04 AM   #8
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Thanks for the information guys!
Can I use Adam's detail spray after the applying the rejex(allow to cure first) to keep up the shine?
Old 12-26-2007, 10:22 AM   #9
mrosa65
CF Senior Member
mrosa65's Avatar
I would guess and say yes, but since I don't own Adam's detail spray I'll let someone who has used it with rejex give you their opinion.
Remember when using a polymer sealant, you should avoid anything that contains a wax or wax type product in it. (Disclaimer - I'm NOT saying Adam's QD spray contains wax)
Some carwash soaps, quick detailers, etc... have wax in it. It may even say it right on the label. This would keep your next application of rejex from properly bonding.
Old 12-26-2007, 10:40 AM   #10
FloydSummerOf68
CF Senior Member
FloydSummerOf68's Avatar
Send a message via AIM to FloydSummerOf68
It would be fine to apply rejex with a gray pad on the porter cable...yes?
FloydSummerOf68 is offline   Reply With Quote
Old 12-26-2007, 11:28 AM   #11
GizmoZ
CF Senior Member
GizmoZ's Avatar
Absolutely. Adam's detail spray is great and it will work fine over Rejex. Do yourself a favor, splurge, and spend the $13 for a blue microfiber towel from Adam's to use with the detail spray. You'll actually need a couple, but after you use one, you'll want lots more.
As mrosa pointed out, you'll want to wash the car with a neutral soap before applying additional layers of Rejex to allow proper bonding.
GizmoZ is offline   Reply With Quote
Old 12-26-2007, 12:03 PM   #12
mrosa65
CF Senior Member
mrosa65's Avatar
Quote:
I guess you could but you really wouldn't receive any added benefit imo. It applies easily by hand, just make sure not to put it on too thick as it can be harder to remove that way.
Old 12-26-2007, 12:21 PM   #13
Guitarstar
CF Senior Member
Guitarstar's Avatar
Love Rejex, A friend recently turned me onto Adams detail spray & Butter Wax.
They work great & smell great!
I am gonna get some!
Guitarstar is offline   Reply With Quote
Old 12-26-2007, 12:26 PM   #14
FloydSummerOf68
CF Senior Member
Quote:
The reason I asked was because I felt it could probably go on more evenly with a small amount using the PC rather than doing it by hand.
Not really for any sort of benefit of trying to work it into the paint or anything.
Old 12-27-2007, 07:23 PM   #15
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
I spoke to a head guy at rejex and he told me that as long as there is no wax or sillicone on the paint, there is no problem applyng rejex. He said I can apply Adams swirl and haze remover, then Adams polish, wipe it off, then add rejex.
Old 12-27-2007, 09:54 PM   #16
mrosa65
CF Senior Member
mrosa65's Avatar
When in doubt, mix a spray bottle with a 50/50 solution of isopropyl and water. Takes all of 5-10 minutes to spray down the car and wipe off and you know it's 100% ready to go
Old 12-27-2007, 10:20 PM   #17
daddoe
CF Senior Member
daddoe's Avatar
Send a message via Yahoo to daddoe
I've done the Swirl and Haze remover and Revive polish, followed by the Rejex and had fantastic results. I had all of the Adams products, so rather than finishing with the Buttery Wax, I thought I would use Rejex to seal the paint. It worked great.
daddoe is offline   Reply With Quote
Old 12-27-2007, 10:31 PM   #18
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Quote:
Exactly what I'm doing! Did you remove any remnants after the revive polish with isopropyl/water before you applied Rejex? Also, I'm using a porter cable for the swirl/polish, did you use a polisher?
Old 12-27-2007, 10:41 PM   #19
daddoe
CF Senior Member
daddoe's Avatar
I used a PC with a white pad for the swirl/polish. Then I used a high quality microfibre cloth wipe off and remove any residue. Then I went straight to the Rejex. No isopropy/water soution was used.
Old 12-28-2007, 01:03 AM   #20
03 Z-oh-6
CF Senior Member
03 Z-oh-6's Avatar
Did you use the swirl and polish at the same time, or did you do all swirl, then all polish?
Reload this Page Another REJEX question :)
Tags
pasadena, portercable, rejex, remover, swirl
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
RejeX Group Buy - Forum Discount from X-Auto Products X-AutoProducts C4 General Discussion 16 05-01-2005 11:56 AM
RejeX Group Buy - Forum Discount from X-Auto Products X-AutoProducts C5 General 22 05-01-2005 09:19 AM
New Group Purchase - RejeX Paint Polish & Protectant X-AutoProducts C5 General 41 11-30-2004 12:14 PM
Sealants .... The More Durable Choice Killrwheels Car Care Discussion 20 11-19-2004 04:12 PM
Durability of NXT tech wax DAVS Y2K Car Care Discussion 15 11-10-2004 11:43 AM
New CF Sponsor - X-Auto Products GROUP PURCHASE X-AutoProducts C4 General Discussion 42 10-26-2004 11:49 PM
Anyone buy/try the Rejex product from X-Auto Andy64 C5 Z06 Discussion 12 08-28-2004 10:42 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
