Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-25-2007, 01:55 PM   #1
o2z51
CF Senior Member
o2z51's Avatar
Default Water spots on Glass????
Hey Guys Im in the process of buying a car and there are water spots on the glass?? Is it possible to remove them?? What do I use??....Merry Christmas
o2z51 is offline   Reply With Quote
Old 12-25-2007, 02:16 PM   #2
Roughrider
CF Senior Member
Roughrider's Avatar
Send a message via MSN to Roughrider Send a message via Yahoo to Roughrider
There are glass polishing products available for that, but most are supposed to be used with a machine polisher for best results.
One of the best things I've found for that is use the cream cleaner for glass top ranges. You can find it in most grocery stores in the kitchen cleaners section. The stuff works excellent, is easy to use and leaves a coating on the glass that water won't adhere to.
Roughrider is offline   Reply With Quote
Old 12-25-2007, 05:57 PM   #3
Mrs. glass car
CF Senior Member
Support Corvetteforum!
Mrs. glass car's Avatar
Great idea!! I use it on the range top, but never thought about using on glass. I am going to the garage and give it a try. Thanks.
Mrs. glass car is offline   Reply With Quote
Old 12-25-2007, 09:04 PM   #4
agentf1
CF Senior Member
St. Jude Donor '10
agentf1's Avatar
I would try some Zaino Glass polish on it before I bought it. If they are etched they may not be able to be removed.
agentf1 is offline   Reply With Quote
Old 12-26-2007, 02:31 AM   #5
sabooher
CF Senior Member
I would try using a claybar on the glass; it won't remove water spots that have etched the clearcoat but it might work fine on glass unless that too has been etched.
sabooher is offline   Reply With Quote
Old 12-26-2007, 01:17 PM   #6
GSjimbo
CF Senior Member
GSjimbo's Avatar
I just bought a new car with the same problem; water spots on the glass. I resorted to an old trick I was shown by a detailer. Use 0000 steel wool and light polishing compound such as Zaino ZPC. Worked great and did not harm the glass.
GSjimbo is offline   Reply With Quote
Old 12-28-2007, 10:02 AM   #7
o2z51
CF Senior Member
o2z51's Avatar
Awesome advice guys thanks, I will give it a shot.....
Old 12-28-2007, 10:06 AM   #8
GS4-LT1
CF Senior Member
GS4-LT1's Avatar
Quote:
0000 steel wool works great on glass and won't scratch.
GS4-LT1 is offline   Reply With Quote
Old 12-28-2007, 12:20 PM   #9
0JPM@AutoBuffs
Former Vendor
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Location: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
I had great results with Zaino Fusion
JPM@AutoBuffs is offline   Reply With Quote
Old 12-28-2007, 07:59 PM   #10
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
Our DP Glass Restorer has a very healthy group of faithful including Bugman who did a write up. Works well by hand and super by machine.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 12-28-2007, 09:40 PM   #11
karol
CF Senior Member
karol's Avatar
You could go to Home Depot and for about $7 buy a product called Spot-X for hard water stains. I worked hard on an SUV with Stoners, windex, polish, rubbing compound, steel wool, silver polish, etc. Nothing worked. Used this and the results were amazing.
It comes in a powder that you mix with water on a sponge. Kinda messy but the results were spectacular for removing spots. Google their site and read more
karol is offline   Reply With Quote
Old 12-29-2007, 09:50 AM   #12
o2z51
CF Senior Member
o2z51's Avatar
awesome thanks, any chance it could damage the paint???
Old 12-29-2007, 05:48 PM   #13
karol
CF Senior Member
karol's Avatar
According to their site it will not harm the paint. Just dont rub it in. Rinse off immediately.
I used blue painters tape around the area and also laid down some cloth for protection. I didnt want any drips on the paint at all. I would not take a chance with any product even if they said it was OK> A little extra prep time is not a big deal.
Old 12-29-2007, 05:57 PM   #14
PAvetter
CF Senior Member
PAvetter's Avatar
I used Adam's Claybar on mine and it took the water spots completely off.
PAvetter is offline   Reply With Quote
Old 12-29-2007, 07:43 PM   #15
C4boy
CF Senior Member
C4boy's Avatar
You could also try Bon Ami powdered cleaner. They make one that's safe on glass and works wonders on cleaning road grime off windshields. I usually keep can in the garage just for that purpose.
C4boy is offline   Reply With Quote
Old 12-29-2007, 09:29 PM   #16
GotVett?
CF Senior Member
GotVett?'s Avatar
I'll give the appliance cream cleaner a try. The top of each window is hard to clean up.
GotVett? is offline   Reply With Quote
Old 12-30-2007, 05:39 PM   #17
Nightshifter
CF Senior Member
Nightshifter's Avatar
If all else fails, because some waterspots etch there way into the glass, you MUST use an orbital polisher (makita) and a polish especially for this purpose. Glass takes a while to polish, and you don't want to build up hit. I removed scratches and all the waterspots, but it took 2 applications of 20 minutes of polishing each section at a slow speed.
Forget doing it by hand, you'll be doing it until next Christmas !
The only way you know if you did get all the spots is to use a special light or angle the glass into the sun a certain way to highlight every single imperfection down to the bacteria level ! I can't stand glass that isn't as perfect as the hubble telescope mirror. Good luck !
Nightshifter is offline   Reply With Quote
Old 12-30-2007, 08:51 PM   #18
rodfl99
CF Senior Member
Default Vinegar
The water in Floridea is hard as a rock and leaves water spots all the time. I found that a mixture of water and white distilled VINEGAR worked quite well. Some spots were extremely tough to remove and , belive it or not, I read about steel wool. Much to my surprise, the steel wool worked great and did not scratch the glass. I tested it on a smal sectionj first, just to make sure.
rodfl99 is offline   Reply With Quote
Old 12-30-2007, 09:25 PM   #19
nmerhaut
CF Senior Member
nmerhaut's Avatar
Any body try toothpaste? It sometimes works;also jeweler's rouge.
nmerhaut is offline   Reply With Quote
Reload this Page Water spots on Glass????
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
remove water spots from glass?? lt4dogman C4 General Discussion 19 07-21-2005 09:48 PM
Water spots on my windows. ALLT4 C4 General Discussion 14 04-11-2005 01:05 PM
OT: water spots on glass.. rocco16 Car Care Discussion 19 08-03-2003 02:10 PM
Do you have water spots on your windows that you can't get out? I have the answer!! SLICKMAN Car Care Discussion 13 07-09-2003 01:17 AM
Hard water spots on the glass?? Stingray1967 Car Care Discussion 12 08-20-2002 06:24 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
