Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-12-2007, 07:25 AM   #1
93 ragtop
CF Senior Member
93 ragtop's Avatar
Default exhaust soot on the back of the car
What works to remove the soot from the paint on the back of the car? To top it off, its a white car.
__________________
93 Automatic White Vert. 4.09 gears, Yank 3000 converter, Hot Cam, ported heads, Exotic Muscle LT headers, magnaflow mufflers Meziere water pump, and professionally tuned by Alvin and it passes emissions!!
My best run 11.82 ET at 116.52 mph. and 1.66 60ft.
My wifes best run 11.71 at 117.31 mph.
362 rwhp
379 torque
93 6 speed White Vert. 383 with a rear mount 85mm turbo. water to air intercooler, 6 pt. rollbar. Gen. 7 dfi. and many more extras. No numbers yet!!
93 ragtop is offline   Reply With Quote
Old 07-12-2007, 07:55 AM   #2
hcvone
CF Senior Member
Support Corvetteforum!
Quote:
Claying will work, an all in one product like Z-AIO, or a paint cleanser/swirl remover product.
__________________
Carl V.
Huntingdon Valley, PA.
www.hcvind.com
hcvone is offline   Reply With Quote
Old 07-12-2007, 11:25 AM   #3
Dale@Adams
CF Member
93 ragtop,
I would wash and dry the vehicle first, then would try a clay bar to remove any heavy soot. Follow with a good polish to help clean the paint and then apply a nice wax/sealant to protect the finish as much as possible.
Thanks and let us know how you make out !
Dale@Adams is offline   Reply With Quote
Old 07-12-2007, 11:28 AM   #4
agentf1
CF Senior Member
St. Jude Donor '10
agentf1's Avatar
I get this sometimes on the silver stripes on my Viper.
Zaino Z-AIO works perfect for this. And as an added bonus once you apply the Zaino it will then just wash right off.
__________________
2001 Viper GTS Sapphire w/Silver stripes
2004 Lightning
2007 335i
2009 Callaway Z06 SC652
agentf1 is offline   Reply With Quote
Old 07-12-2007, 11:29 AM   #5
gmblack3
CF Senior Member
gmblack3's Avatar
I have used ZAIO after washing. It has chemical cleaners in it. It will work by hand as well. It will also protect so that in the future it should be easier to get the soot off.
gmblack3 is offline   Reply With Quote
Old 07-12-2007, 12:37 PM   #6
C4boy
CF Senior Member
C4boy's Avatar
Do you mean like this? I tried Megs paint cleaner, Menzerna FP II and finally settled on using IP and cleaning by hand. It was that bad.
C4boy is offline   Reply With Quote
Old 07-12-2007, 12:40 PM   #7
mrosa65
CF Senior Member
mrosa65's Avatar
If the spots are light some carwash soap should remove them. If they're really baked on, I've had good results with Goo-gone and WD-40.
Since I've started using Zaino, they easily wash off.
mrosa65 is offline   Reply With Quote
Old 07-12-2007, 10:24 PM   #8
93 ragtop
CF Senior Member
93 ragtop's Avatar
Thanks for all the response. I tried a little wd-40 and it does not seem to do anything. I then tried a small amount of the white polishing compound and that does seem to break it down.
In the past I have used the Zaino products. z-1, 2, 5 I still have. Its been a few years and I didnt realize they had come out with the new products.
Again, thanks for everyones help!!
__________________
362 rwhp
379 torque
Old 07-15-2007, 10:15 AM   #9
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
Might try a product called Amazing Roll-Off. You will see it is paint safe and a very effective cleaner from wheels, to wheelwells, and the like. Also highly regarded in the boating industry.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 07-15-2007, 12:39 PM   #10
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
i have this problem all the time. Weekly washings will keep this down to a minimum. easiest way to get rid of them for me was using a clay bar.
DPG is offline   Reply With Quote
Old 07-15-2007, 02:13 PM   #11
C4boy
CF Senior Member
C4boy's Avatar
Just as a side note...If you're getting exhaust soot out your exhaust, your car is probably running too rich and something needs to be corrected. The timing on the '82 above was 3* late. I can't wait to see what the O2 sensor looks like.
Reload this Page exhaust soot on the back of the car
Tags
back, c5, car, clean, exhaust, paint, remove, soot
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Phoenix is home: Cartek 447 first impressions SPEED DOG C5 Tech 35 04-16-2005 12:25 AM
Exhaust keeps turning my tail pipes black: Is this normal? abailey269 C5 Tech 17 10-09-2004 10:45 PM
Whats it mean to have Black suit all over the rear of the car? Red5 C5 Tech 25 02-22-2004 02:18 AM
Exhaust problems with Z06 ZPerb C5 Z06 Discussion 18 12-06-2003 01:49 PM
Loss of power, Glowing exhuast manifolds, And a leak [L-98] bill mcdonald C4 Tech/Performance 18 06-23-2003 03:32 AM
Need real answer: Does removing the cat's increase power? QUIKAG C5 Tech 66 12-14-2002 08:14 AM
another REALLY upset Z06 customer with the ''Oil comsumtion'' problem :( Z06 THIS C5 Z06 Discussion 18 03-31-2002 12:38 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
