Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Zaino advice on my C5?
Old 07-07-2007, 05:34 PM
RRM707
RRM707's Avatar
Default Zaino advice on my C5?
Can someone tell me the order in which their products go on? They seem to have ALOT of stuff! I have a silver C5. Thanks!
Old 07-07-2007, 05:56 PM
Timbrr
Timbrr's Avatar
Default Zaino Advise
First wash the car with Dawn soap
Clay bar the finish and wash again
Apply Z5 then
Apply Z2 finally
Apply Z6 or 8
You can apply Z6 or Z8 between coats of Z5 and Z2.
Old 07-07-2007, 07:51 PM
RRM707
RRM707's Avatar
Apply Z5 then
Apply Z2 finally
Apply Z6 or 8
Wow! I guess looking good requires more than just "waxing" it!
Thanks!
Old 07-07-2007, 08:11 PM
Bowhunter2001
Bowhunter2001's Avatar
Thanks!
It does if you want it to look like this!
Old 07-07-2007, 08:33 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Here is what I do on my Machine Silver 2004 Z06. I have a friend that has a 2004 Machine Silver Coupe and his car is noticably darker than my car ... We suspect its the Zaino really brightening up the silver.
Web page
http://mysite.verizon.net/res0aae8/webpage.html
1.) Wash or dust off the car. Only use a household dish detergent if you want to strip all the wax off the car ! Use automobile washes if you don't want to strip off the old polish.
2.) Z-5 PRO Show Car Polish for Swirl Marks and Fine Scratches. Use this for as long as it takes to remove the fine scratches. Its not required once fine scratches are gone.
3.) Z-2 PRO Show Car Polish for Clear Coated Car Finishes. Use this every time you wax the car.
4.) Z-8 Grand Finale Spray Seal. Use this after every application of the above products. Also use this in between polish jobs to retain gloss look. I spray this on a small micro fiber sponge, and rub it on a small area of my paint, then quickly dry it off with a micro fiber towel.
If you use the Z5 or Z2 inside your dry garage its ok to leave it on over night. Sometimes I put a coat of Z2 on Friday night, and remove it Saturday night. Be sure NOT to do this in direct sunlight though.
Its all very easy to apply and take off (compared to the 1000 other products I have tried). The shine is second to none that I have seen so far.
I have not used the clay bar.... I'm not sure what advanage it will give me on my Silver car... Anyone ?
Hope this helps....
Toque
Old 07-07-2007, 08:37 PM
WWK888
WWK888's Avatar
You might want to go to the Car Care Section, there is a wealth of information there.
http://forums.corvetteforum.com/forumdisplay.php?f=10
Old 07-07-2007, 08:40 PM
Nyvetteguy007
Support Corvetteforum!
Nyvetteguy007's Avatar
Web page
Hope this helps....
Toque
Im a Zaino nut..
One thing everyone is missing though is the new Zaino CS (clear seal).....after doing either Z2 or Z5 and prior to putting on Z6 or Z8 apply CS...holy S*&T...th shine is AMAZING....you do need to give it a few hours to cross link though....check out more on it in the car care section of the forum...
Old 07-07-2007, 08:45 PM
WetteVette
WetteVette's Avatar
All these zzzzzzzzz's are putting me to sleep!
Old 07-07-2007, 08:50 PM
Nyvetteguy007
Its confusing in the beginning BUT well worth it.....utilize the car care portion of this forum and Zainos website.....you'll get the hang of it...
Old 07-07-2007, 08:54 PM
Silverbullet00
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
The clay bar takes off crap you can't even see until it's gone! The dif is incredible, especially on older cars!
Old 07-07-2007, 09:02 PM
Nyvetteguy007
The first time you clay a car you will not believe your eyes....you need to wax it afterwards though as it takes the wax off....
Old 07-08-2007, 08:10 PM
waunavet
waunavet's Avatar
St. Jude Donor '20
Apply Z5 then
Apply Z2 finally
Apply Z6 or 8
I've got a pewter 1999.
Old 07-08-2007, 09:54 PM
CCA Corvette Parts
Premium Supporting Vendor
CCA Corvette Parts's Avatar
St. Jude Donor '07-'08,-'13-'14, '16-'17
Apply Z5 then
Apply Z2 finally
Apply Z6 or 8
Same routine here...
Peace
Chip
__________________
..................Click for
Old 07-11-2007, 09:27 PM
mrosa65
mrosa65's Avatar
Apply Z5 then
Apply Z2 finally
Apply Z6 or 8
This is pretty much the order I do it in. I skip the Dawn if I'm claying or using an abrasive and use only Z6 between coats. I save the Z8 as the "cherry on top".
Old 07-12-2007, 01:08 PM
Cole
Cole's Avatar
Thanks!
It HAS gotten simpler. Zaino has new products. The key remains in surface prep and the lessons carry over to other systems. A clean paint surface really is important. If you visit the Zaino Web site, they have introduced ZAIO (All in one) and it is a superb product for any car and very fast and easy. A simple topping with the new CS is all that is needed after ZAIO. Many of us use Z5 or Z2 after ZAIO for some extra zing, but I use ZAIO and CS on my White Denali and it really zings. Simple and fast. On my Torch Red Corvette, I add a layer of Z5 prior to the CS. Z5 seems to really snap out the red so I stick with it. Once the car is prepped, working with Zaino - or any other final topping - really is fast and easy.
Old 07-12-2007, 01:21 PM
John Vuckovich
John Vuckovich's Avatar
Try Z in the bedroom! It works like Dead Head.
Two coats on the head and your good for hours! Try it, I swear it works!
Old 07-12-2007, 01:25 PM
WWK888
WWK888's Avatar
Sounds like you have been experimenting quite a bit to solve your problem...
To Zaino advice on my C5?
Quick Reply: Zaino advice on my C5?
