Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-05-2007, 08:57 PM   #1
mikeyc6
CF Senior Member
mikeyc6's Avatar
Default Best spray wax?
OK, it's hell getting old, but I need to find a compromise between Zany (pun intended) applications of a half dozen layers of wax and endless buffing, and a decent protection/shine. I'm looking for the best spray on-wipe off wax or polish that will give me the best protection against bugs, UV, and other contaminants. Obviously I'm not expecting Zaino/Rejex quality protection but if you had to compromise and use an easy spray on/wipe off product and you wanted the best protection you could get with that type of product, what would it be?
Thanks,
Mike
mikeyc6 is offline   Reply With Quote
Old 06-05-2007, 09:02 PM   #2
Zymurgy
CF Senior Member
Support Corvetteforum!
Zymurgy's Avatar
Why not Rejex? Very easy to apply and wipe off. No buffing required and you get a polymer based paint protection.
Zymurgy is offline   Reply With Quote
Old 06-05-2007, 09:02 PM   #3
marct6444
CF Senior Member
St. Jude Donor '07-'08
marct6444's Avatar
Maybe you should try the new Zaino Z-CS Clear Seal spray. Check it out.
marct6444 is offline   Reply With Quote
Old 06-05-2007, 09:07 PM   #4
mikeyc6
CF Senior Member
mikeyc6's Avatar
Quote:
Wow! Just looked that up, and it looks great! I'm going to order some. As to why no Rejex: I'm trying to avoid the double rub. Don't want to have to rub the stuff on and then spend another step buffing it off which is why I was looking for a spray. The CS spray looks like the ticket! Thanks.
Mike
Old 06-05-2007, 09:12 PM   #5
1yy07vette
CF Senior Member
Quote:
Mike
try spray on turtle wax ! it's cheap,can pick it up at wally world,
it's safe for the clear coat and can be put on wet or dry !
now hows that for laziness ?
1yy07vette is offline   Reply With Quote
Old 06-05-2007, 09:13 PM   #6
NDMIKE88
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
NDMIKE88's Avatar
Send a message via AIM to NDMIKE88
Do spray and wax belong in the same sentence together?
NDMIKE88 is offline   Reply With Quote
Old 06-05-2007, 09:18 PM   #7
Alan V
CF Senior Member
Default Try ICE
I've been a dedicate Zaino user, but I just applied Turtle Wax Ice on my 07 coupe in velocity yellow. Super easy to apply and just too simple to buff. The results were amazing -- the finished sparkles. Costo has the whole Ice kit for $19 with a bottle of detail spray. You can do a whole car in 20 minutes. Worth the try.
Alan V is offline   Reply With Quote
Old 06-05-2007, 09:21 PM   #8
1yy07vette
CF Senior Member
Quote:
without getting into the science of protective coatings .
let's just say we disagree. oh, and by the way, i can attest to the
protective coating against bugs etc.... sorry it doesn't cost a bundle
or require a lot of work and the car looks great !
Old 06-05-2007, 09:55 PM   #9
cheelo18
CF Member
its not spray but P21S goes on real easy and comes off even easier - no white residue
cheelo18 is offline   Reply With Quote
Old 06-05-2007, 11:28 PM   #10
Guitarstar
CF Senior Member
Guitarstar's Avatar
6 days after washing & spraying Griots Spray On Wax while still wet, just dry.
Click the image to open in full size.
Guitarstar is offline   Reply With Quote
Old 06-05-2007, 11:41 PM   #11
awahl63
CF Member
Send a message via AIM to awahl63
OCW (Optimum Car Wax), Duragloss Aquawax, Optimum Opti-Seal, Prima Hydro, Zaino Clear Seal...there are a ton of good ones
awahl63 is offline   Reply With Quote
Old 06-06-2007, 12:30 PM   #12
crawfish333
CF Senior Member
CI 6-7 & 9 Veteran
crawfish333's Avatar
Quote:
I tried Ice a few days ago. I appied it right on top of 2 fresh coats of the Meguire's NXT. The results were amazing. I could not believe how good this stuff worked. An the kicker is that it only takes about 20 minutes to do the whole car. If it does not strip the old wax (?), this would make a fantastic alternative to detailing spray and is really easier to use. Detail spray can sometime cause cloudy spots if it is appied in the hot sun, this stuff won't. Any other experiences (good or bad) with Ice?
crawfish333 is offline   Reply With Quote
Old 06-06-2007, 12:58 PM   #13
capevettes
CF Senior Member
capevettes's Avatar
Zaino Z6 and Z8 work like spray-on QD's. Great for maintaining shine between full details. Z6 has some mild cleaning capabilities and gloss enhancement. Z8 really makes the shine pop and gives the surface that slippery feel.
capevettes is offline   Reply With Quote
Old 06-06-2007, 02:36 PM   #14
BanditSRT
CF Senior Member
BanditSRT's Avatar
Duragloss Aquawax... You can get this from AutoGeek. After trying it, I went back and bought a gallon. The stuff rocks!
http://www.autogeek.net/duragloss-aquawax--951.html
BTW, this stuff is very similar to Z8 and it's less than half the price
BanditSRT is offline   Reply With Quote
Old 06-06-2007, 04:55 PM   #15
Comfortably Numb
CF Senior Member
Comfortably Numb's Avatar
You ask a question about what spray wax to use and half the responses are about Zaino/Rejex (a polish). I'm going to try ICE for the heck of it but I am a Zaino user myself (there I got my plug in)
Comfortably Numb is offline   Reply With Quote
Reload this Page Best spray wax?
Tags
best, corvette, spary, spray, sprayon, wax
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
QDer's ... Instant Detailers ... Spray Wax ... Spray Sealant Killrwheels Car Care Discussion 11 04-20-2005 08:26 PM
Best Tire Dressing Product Z Factor Car Care Discussion 55 12-30-2004 11:09 AM
Best Leather Care Product Z Factor Car Care Discussion 53 09-02-2004 10:28 AM
Anyone here in the Z06 section tried the new NXT wax? Piranha C5 Z06 Discussion 18 04-14-2004 11:35 PM
WHAT IS THE 'BEST' POLISH, WAX, ECT. TO USE ON VETTE? daffyky Car Care Discussion 57 01-10-2003 10:35 PM
Best car wax at an auto parts store CorvetteGeo C4 General Discussion 31 10-02-2002 12:01 PM
What is the best protection for freshly painted steel surfaces? Factory Correct Resto 26 05-19-2002 02:40 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
