Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Calling all Zaino experts...please posts your steps for a newbie
Old 06-05-2007, 03:31 PM
bigfrank
bigfrank's Avatar
Default Calling all Zaino experts...please posts your steps for a newbie
Just received a PM from a member. Here's what he goes through,
1. Wash car with Dawn
2. Menzerna IP w/Orange pad speed 6 on PC. Go over each area 1 time or more if needed to get swirls.
3. Menzerna FP w/white pad 1 time speed 6 on PC.
4. Z5 Zaino 3 coats.
When you think it looks good then go to 5.
5. Z2 2 coats.
6. Z6 entire car
7. Zaino CS.
8. Z6 entire car
9. Z8 entire car
Please posts the steps that have worked for you and any other products or equipment involved.
Old 06-05-2007, 03:43 PM
ZaneO
ZaneO's Avatar
That's a pretty hardcore regimine.
There's no need for the Dawn wash when you're polishing. I rarely apply more than 2 coats of Z5 and/or Z2, but you can apply as many as you like, as long as you allow adequate curing time.
Old 06-05-2007, 03:57 PM
hcvone
Support Corvetteforum!
hcvone's Avatar
Received 1,765 Likes on 968 Posts
As said 2-3 coats is all I have ever applied in a day, on dark colors I would apply 2 coats of Z-5 and 1 coat of Z-2, any more than 3 coats you will want to do over a 2 day period to allow proper drying time, if you are buffing 2 coats of Z-5 and 1 coat of Z-2 will be all you need.
Old 06-05-2007, 04:09 PM
Bob Ward
Bob Ward's Avatar
The Menserna FP is advertised as having some oils in it. So you may want to do a 50/50 alcohol wipedown before going to the Zaino.
Bob
Old 06-05-2007, 04:42 PM
agentf1
agentf1's Avatar
St. Jude Donor '10
After paint is properly prepped I like a coat of Z5p and then usually follow up with either a second coat of Z5p or Z2p. I will then add a coat of CS and after it dries I spritz with Z8. This is all I need for the "ULTIMATE" Shine. That is IT, no million coats needed.
Note: If I use a non Zaino product for perpping I will sometimes do a 50/50 wipe or Z7 wash. If prepping with ZPC or Z-AIO just move right on to your Zainoing.
I also do the baggie test first to see if claying is required.
Of course you cannot forget the Z16 on tires and Z9/Z10 on the leather interior.
Old 06-05-2007, 07:00 PM
JJU
JJU's Avatar
Cruise-In II Veteran
There is no need to apply Z-6 and then Z-8 on after it.
Just go with the Z-8.
I agree with what others have said.
Old 06-07-2007, 10:46 AM
bigfrank
bigfrank's Avatar
Great input guys! Thank you.
Old 06-07-2007, 12:17 PM
IAIA
IAIA's Avatar
Whatever you use for polish, Zaino product or not, you should wash the car before the Z5 (Dawn isn't necessary...just any good wash stuff). Helps get the PC dust off and any areas that still may have latent PC or polish.
Old 06-07-2007, 02:52 PM
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
To Calling all Zaino experts...please posts your steps for a newbie
Quick Reply: Calling all Zaino experts...please posts your steps for a newbie
