Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-29-2007, 02:46 PM   #1
Two007
CF Member
Two007's Avatar
Default Hard Water Spots
I am living in a condo for two years, finishing up my employment with my company in NJ. My coupe has to sit outside, although it kills me to let it do so. I am working on getting the maintenance guy to fix it, but the sprinklers keep hitting my car. NJ has some very hard water, and it leaves deposits on my car. Anyone know of a good product or best method to safely remove them? I have used Adams glass cleaner and detail cleaner, but it seems the only sure way is to completely wash the car over again. Any thoughts?
Two007 is offline   Reply With Quote
Old 05-29-2007, 03:03 PM   #2
crawfish333
CF Senior Member
CI 6-7 & 9 Veteran
crawfish333's Avatar
There are a lot of discussion threads on this topic in the "Care Car Products" section of the forum. You may want to go over and make a search.
Some methods I am familiar with are as follows:
Wash the car with a good car wax remover or Dawn dishwashing detergent. After the wax is off the car, use a clay bar to remove water spots and other environmental particles. Be sure and keep the area you are using the clay on lubricated with either detail spray or (more inexpensively) a solution of car wash and water. If you use the car wash solution be sure and keep the area rinsed with clear water. After claying the car, rewash and apply a good wax or polish (like Zaino's) Make sure and dry the car really well after each wash job, or you'll get more water spots.
If the water soots are really bad, I have heard of more severe treatments (using alcohol solutions) but I have never had to go that far so I cannot recommend it. If it is really bad, it might be better to take it to a good detailing shop.
crawfish333 is offline   Reply With Quote
Old 05-29-2007, 03:08 PM   #3
RED2008Z06
CF Senior Member
Support Corvetteforum!
RED2008Z06's Avatar
I've read 50/50 vineagar/ water solution.. good luck
http://forums.corvetteforum.com/show...ht=water+spots
RED2008Z06 is offline   Reply With Quote
Old 05-29-2007, 03:11 PM   #4
ben dover
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. TX
A clay bar should do it unless it has etched the clear coat, then you may have to use a microfinish type polish.
ben dover is offline   Reply With Quote
Old 05-29-2007, 03:18 PM   #5
Die2Win
CF Senior Member
Die2Win's Avatar
[QUOTE=Topless06;1560443005]I've read 50/50 vineagar/ water solution.. good luck
I have been using regular white vineger cut with water, (how much water depends on the spots to be removed) and it won't hurt the paint.
Make sure to use a good top treatment like RejeX or Zano once your car is clean and dry.
Die2Win is offline   Reply With Quote
Old 05-29-2007, 04:39 PM   #6
mlongo99
CF Senior Member
Cruise-In VIII Veteran
mlongo99's Avatar
A clay bar has worked well for me.
mlongo99 is offline   Reply With Quote
Old 05-29-2007, 04:41 PM   #7
0SicMSP - Daniel
Former Vendor
SicMSP - Daniel's Avatar
Quote:
SicMSP - Daniel is offline   Reply With Quote
Old 05-29-2007, 05:31 PM   #8
4thC4at60
CF Senior Member
4thC4at60's Avatar
White vinegar diluted 50/50 if you wish, been using it on high-end cars for 42 years.
4thC4at60 is offline   Reply With Quote
Old 05-29-2007, 05:48 PM   #9
drivinfast
CF Senior Member
drivinfast's Avatar
Send a message via Yahoo to drivinfast
Default medium pressure w clay
I pressed too hard removing water spots from hard water and ended up with swirls from clay, I didnt believe it at first but going to bugmans site it is confirmed. just test a small spot first, if it has been several months of this going on, i doubt vinegar will work, didnt for me
drivinfast is offline   Reply With Quote
Old 05-29-2007, 05:51 PM   #10
Wayne O
CF Senior Member
Wayne O's Avatar
While waxing my car the other day I noticed (what appeared to be) extensive small water spots on the hood. I washed the front of my car about 6 times with Dawn attempting to remove the wax. I then clay-barred the front of the car. There weren't a lot of contaminants on the car to begin with but it did remove about 80% of the small spots.
__________________
2005 Corvette C6 Coupe
Magnetic Red Metallic II/Cashmere, MN6, 1SB, F55
Lingenfelter 403 Conversion, LG Pro Headers (coated), Corsa Sport Exhaust, Lingenfelter CAI, Accusump, LGM Coil-Over Suspension & Bump-Steer Kit, T1 Sway Bars, Pfadt Control Arm Bushing Kit, Elite Eng. Tunnel Plate & Oil Catch-Can, SKF Racing Hubs/Bearings, AP Racing Brakes, DRM Brake Ducts, Custom Roll Bar, Sparco Seats, Wide-Booty, CCW C10 Wheels,
Setup: LG Motorsports
Thanks to: 21st Century Muscle Cars
Wayne O is offline   Reply With Quote
Old 05-29-2007, 06:27 PM   #11
Steve Germany
CF Senior Member
Steve Germany's Avatar
Water and vinegar - and then a car cover!
Steve Germany is offline   Reply With Quote
Old 05-29-2007, 06:32 PM   #12
Rob Willis
CF Senior Member
Rob Willis's Avatar
http://www.autogeek.net/clinhofianda.html (Forum Sponsor)
OR
http://crspotless.com/
Rob Willis is offline   Reply With Quote
Old 05-29-2007, 07:17 PM   #13
shalenss
CF Senior Member
shalenss's Avatar
Try wire wheel cleaner,spray on ,wipe it and wash it of right away.It works better than vinegar or anything else.But should be used as last resource......
shalenss is offline   Reply With Quote
Old 05-29-2007, 07:25 PM   #14
V4Vette
CF Senior Member
V4Vette's Avatar
Yes. Vinegar is acidic and will disolved the calcium deposits. I remember this from Chemistry.
V4Vette is offline   Reply With Quote
Old 05-30-2007, 03:52 PM   #15
Two007
CF Member
Two007's Avatar
Default Thanks!
Thanks to everyone for their input. I went home, mixed up some vinegar and water 50/50 into a spray bottle. Misted the spots, wiped them right off with a microfiber towel. Perfect! I knew I could count on you guys. Now "Little Red" is all shiny again!
Reload this Page Hard Water Spots
Tags
bakersfield, bar, calcium, car, clay, corvette, deposit, edmond, hard, water
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
southern , CA hard water spots x-mann C6 Corvette General Discussion 20 06-20-2005 11:53 AM
Hard water spots on the glass?? Stingray1967 Car Care Discussion 12 08-20-2002 05:24 PM
Hard Water spots on windows TONYS68L36 Car Care Discussion 15 07-14-2002 02:34 PM
hard water spots !!! how to remove??? guywade C4 Tech/Performance 13 06-01-2002 02:20 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
