Water Spots on New Paint Job
My wife's 93 Camry received a new paint job (metallic green) about a week ago. The paint looks great and I was told by the painter to hold off applying any waxes/sealants for a period of two weeks Unfortunately, my wife parked the car too close to the neighbors sprinklers and the car now has water spots on the lower 1/3 portion of the hood and the front bumper
I washed the car yesterday but the spots are still there.
What is the recommendation to remove the water spots? Will a 50/50 mixture of distilled water and vinegar solve the problem? Is it safe to use that mixture on new paint?
Thanks,
Mordi
Thanks,
Mordi
Water spots can be tough to remove some times. I would start out with the vinegar and water but you will probably need to use a mild paint cleanser or swirl remover and a ROB to remove them. Not to scare you but I have seen some severe cases that have actually etched the paint that require wet sanding to fix the problem.
